My Ilo TV will shut itself off after a short period of time. When I immediately turn it back on, it will immediately shut itself off again. If I let it sit a minute before turning it back on, it will stay on for about 20 minutes before shutting off. Is it over heating? I checked to make sure the sleep timer was off and it is.
Hi Drew..Your backlights are bad, common issue, there are some shorted diodes in the lamp strips, the over current section of the inverter is shutting down, then the set reboots, senses over current and shuts down again ect
searching for a therminal defect on an active or passive electronic (smd) component
A canister coldspray can sometimes be helpfull when its come on when turns green spray and look if there is difference in time and a hair dryer for searching an therminal defect somewhere. resistor or active component.
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
You have a short in the power supply .
you need an experienced teck to check the tv. Your problem may be a shorted transistor or something more complex. Let me what aera you are frome, maby i can recomend a teck that is factory authorized to repair your tv. [email protected]
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
If it's staying on for just a short period of time it sounds like there is a sensor that is giving the unit a faulty condition (Perhaps for reason or due to a fault in the sensor). There are normally a few temp sensors in the TV around the Lamp and Ballast. They may be bad, or the lamp or ballast is just generating too much heat.
