Mitsubishi WD-57731 57" Projection HDTV Logo
Posted on Nov 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No picture and high pitch sound. I have already replace the bulb
No picture and high pitch sound and I have already replaced the bulb. Quick review says probably the color wheel. How do I replace this?
model 57731
Anonymous
Level 3:
  • Master 647 Answers
  • Posted on Nov 08, 2009
Anonymous
Master
Level 3:
Answers
647
Questions
Helped
149978
Points
2098
This will give you the general idea, although it's not for your model. They're all generally the same.
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
50 " DLP makes a high pitch squilling sound and shuts off several times
Check and replace its color wheel. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
When The TV is running it makes a high pitched whinning that seems to be coming from the projector
its a bad color wheel and you may be able to replace it. You Tube has videos for this.
Look where the lamp faces and see if wheel missing segments or shattered.
No picture on my philips 42PFL7422D/137 lcd I have already replaced both master and slave boards and my picture returned. After about a month or two the tv started to make a high pitch whistling sound...
do you have sound but no pix?its the video board if you have neither it will be the board where your coax and audio inputs connect...just a matter of getting the right boards off of e-bay GOD bless
1helpful
No picture but sound
most likely the color wheel needs replacing.
I have a 47 " samsung tantus 1080i hdtv. It makes a high pitched whistle sound at times which is very annoying(seems to come on when the sound on the tv is also high pitched). I can take the back off and...
You Seam to have already found the problem!, If your Wiggling A Cap or Coil and the sound gos away! its the cause of the problem!, replace it, Or A Quick fix is to Use 100% Silicone around problem cap/coil ~ But Let it Dry! before use (24hr) Geo*
2answers
No picture on Samsung HLN5065W
sounds like the color wheel has gone bad..the part is not very expensive but it takes some work to replace it
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
