Xerox WorkCentre M128 Copier Logo
Posted on Nov 08, 2009
Error 016-311 xerox workcentre M128 - Xerox WorkCentre M128 Copier
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Nov 11, 2009
Anonymous
Contributor
Level 1:
Answers
24
Questions
0
Helped
42775
Points
47
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
nagen samadder
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Aug 30, 2016
nagen samadder
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
9614
Points
1 Related Answer
Anonymous
  • 2072 Answers
  • Posted on May 19, 2008
SOURCE: Xerox WorkCentre M128 - 016 - 782
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
arrwup.gifInitial Action Refer to BSD 16.1.
Power OFF/ON
arrwup.gif Procedure Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
1helpful
How do I clear fault code 016-311 for workcentre 7345
That error indicates the scanner is not installed. Check the connection from the scanner to the main ess board and reseat if necessary. If cable is damaged, replace with part number 117K38440.
http://www.iteminconline.com/117k38440_117k38440-xerox-workcentre-7425-iit-controller-cable.htm
Xerox WorkCentre Pro 123 linux driver ?
if you open your web browser, put in
www.xerox.co.uk, go to cusomer support then to suport and driver,
there put
  • WorkCentre M123/M128 and then your operating system. From there you should find the driver package for the linux system
Download driver workcentre m128 for windows 7
Here you go:
http://www.support.xerox.com/support/workcentre-m123-m128/downloads/enus.html?operatingSystem=win7
Problem connecting Win 7 64-bit to Xerox Workcentre M128 printer - Windows is giving a "no suitable driver found" error.
Try this link, it goes directly to the 64 bit driver download site.
http://www.support.xerox.com/support/workcentre-pro-123-128/downloads/enus.html
If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
You will find 32, 64 bit drivers for all OS.
Cannot print to Xerox WorkCentre M128 after upgrading XP to SP3
plz tell us how i can remove spanner in my copyer toshiba 2050
3helpful
Reset password for Xerox M128
What password are you wanting to change? You can change any password, except Auditron access without changing the configuration.
Even changing the auditron does not change the machine settings, that will just make you set the limits.
You can change any password safely without affecting the configuration..
I need a owners manual
Go to Xerox.com click on support and drivers, then enter 450cp into the search box, then click on documentation. You can download that guide from that site.
2helpful
Power OFF/ON
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
