You can only reset the TV when you have the remote as it requires holding down the RESET button on the remote control, then pressing the POWER button on the TV front panel. The TV will turn itself off, then back on again. Then release the RESET button.
Regarding your problem with the TV not staying on for 3 seconds, you can try unplugging the unit for at least an hour to perform a hard reset of the microprocessor. If the unit still doesn't stay on, you need to check the power supply or the entire board for any blown or bad capacitor, shorted terminals due to accumulation of dirt, or broken solders. It may be a tedious task and requires an electronic prowess to do.
Kudos and thanks for using Fixya.
My Sony T.V when i power it on it the light turns green but my screen is pitch black how can i fix that or do i need a professional to do that.
Good day.
This indication of your unit may have nothing to do with resetting it. It actually denotes that there is something wrong with the circuitry inside.
If you can open your unit and check for loose contacts particularly on the power supply section, horizontal section and on the system section.
Response is highly appreciated.
chris
If my tv is insane stand by what should I do when it does not turn on
SOURCE: Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
Follow the instructions from the image provide and see if that works, if it does not work; you have a hardware failure in your TV. The hardware failure could be the HOT or flyback transformer.
Let me know if you need further assistance.
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Point the Sony remote control at the TV and press and hold the "Up" arrow button.
Push the "Power" button on the TV while holding down onto the "Up" button. Release the "Up" button when the TV turns off, then turns back on.
Select "OK" when shown the factor settings and the television has completed its TV reset
I have a Sony WEGA television and it is on stand by how can we reset it or turn it on WITHOUT a remote
What about the memory to wega sony
