Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i install a toner chip on my hp Cp2025
I'm new at this and was wondering how do i install a toner chip on my hp Cp2025 color laser printer? can anyone help me?
Clive
Level 3:
  • HP Master 882 Answers
  • Posted on Nov 18, 2017
Clive
HP Master
Level 3:
Answers
882
Questions
30
Helped
212822
Points
3292
TONER CHIP on CP2025 printer:
This resource may help
http://resources.lasertekservices.com/hp-smart-chips-overriding-this-lockout-mechanism-with-reset-chips/
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
how do i install a toner chip on my hp Cp2025 - samsung_cyan reset chip-4febss1ixlhhr5zh2r4k1b5y-2-0.jpg
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Sep 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
5688
Points
5
This worked for me: I put in a black after market cartridge (off ebay) and got the "remove shipping lock" error. I swapped chips from the empty HP cart and the after market cart. Symptoms followed the chips: empty HP cart got "remove lock" error" and the new after market cart showed empty. I bought a set of reset chips on ebay and installed the black chip on the new aftermarket cart and it worked flawlessly. You don't have to break or cut anything to swap the chips. You can work it out with a small jewelers screwdriver. You can also use the chips to extend the life of an "empty" cartridge because they're not really empty.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
822
Points
When trying to install a toner, it says "REMOVE SHIPPING LOCK FROM YELLOW CARTRIDGE"
Anonymous
Level 1:
New Friend:
  • Posted on Mar 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
822
Points
They're called "toner cartridges."
- See the instructions that came with your printer, but here are the basics
The HP Color LaserJet CP2550 has 4 toner cartridges, one black and three color. Only one cartridge can be changed at a time. They are on a rotating carousel. So you first press the Rotate Carousel button until the cartridge you want to change is selected, then turn off the printer, open the top, pull out the old cartridge, put in the new (being sure it's the correct color), then pull off the tab that keeps the toner from leaking.
HP's toner cart installation instructions are at
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00242813/c00242813.pdf
and the general manual is at
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00242826/c00242826.pdf
toner cart stuff starts on page 12.
If your computer will not open these pages, you need the free Adobe Reader, get it from
http://get.adobe.com/reader/
(I suggest you click to uncheck the "Free McAfee Security Scan Plus.")
Hp laser jet 300/400 10.1000error
10.10 error means it does not recognize the chip on the cartridge or that the seal is still in cartridge need new cartridge
2answers
HP color laserjet cp2025 will not print. Help.
No.
Very few printers will print if they're out of toner, even if the colour toner is exhausted and the print job is only black. Replace the empty toner and if this is the only problem, the printer will continue printing.
I have a 1" wide black smear on the right page edge when using my HP CP2025. Any ideas on how to fix this?
clean the drum if you can get to it easily and also the toner but you may need a new toner and/or drum
How to make a dell 2850 to print on a HP color laser jet CP2025
Download the HP universal driver, plug in printer turn it on. Select the HP universal driver.
2answers
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
15helpful
HP Color Laser Jet CP2025. Replace Supplies message on screen and can't get it off. Put in a new print cartridge. Message still won't go away. Please advise how I can get a User Manual for this...
HP Color LaserJet CP2025 - "Replace Supplies" message.
black cartridge is blinking. Printer won't print and message will not go away. Any suggestions?
4helpful
2answers
Cannot print in black because color cartidge is out of ink
There is a 'low toner' override in the menu system, but if this has NOT been set already, a 'flag' will be set on the chip on the cartridges that are low/empty.
The printer needs to 'see' cartridges that are usable, i.e. NOT empty, in order to function.
It is possible to replace just the chips on the colour cartridges, but then any colour printing quality could be compromised of course, as the colours will be low/empty. You would then be able to use the printer as if it were a mono laser, just changing the black cartridge when needed
5helpful
3answers
Toner Cart chip reset for Ricoh Aficeo sp c400dn
I believe you will need to purchase and install a reset chip. You can find them for the Ricoh C410 here at www.cfriends.com (that links straight tothe ricoh page - but if you need to search, type in "c410" into the search field on their site).
k24674
Grand Canyon Tech
Grand Canyon Tech
