Linksys WRT160N Wireless Router  Logo
Posted on Nov 07, 2009
We forgot our Linksys WRT160N network key/password
Can't get my friends motorola photon to connect wirelessly with my linksys WRT160N
Please see if you have a secured wireless network.
Go to 192.168.1.1 from Internet explorer.
User id =blank
Password =ADMIN
Go to wireless security tab and get the security key from there
try this while connecting to the network.
Forgot password how do i change it
Turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
I forgot my wep key and router username/password
Use first the default username and password according to your router's manual. If it doesn't work reset the router. Look for the reset pin hole on the back of the router. Press and hold it down for 1 seconds.
After that use the default username and password for sure this time it will work. As soon as you are able to access the configuration page of your router please setup a new WEP key to keep you network secured.
I forgot the wifi password
The default password is "admin" with the username as "admin" as well. If you have changed the password and forgotten it, then feel free to reset the router to factory settings by keeping the Reset button on the router pressed for more than 30 seconds.
Linksys routers are simple home based or small network based routers. So unless you have set up your router for some special functions, you won't lose anything that you can't set up again.
I forgot my network password. Is resetting the router the only way to connect?
Yes unless you gave someone else the password. Sorry I couldn't be of more help.
Forgot passphrase
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
I forgot my password/registration key
are you speaking about the wireless password for the network ?
For that you will need to access the router set up.
Click Here for step by step solution
I have forgot my security password for my wrt160n when I tried to unsecure my network aND NOW TO GET WIRELESS i NEED THE SECURITY PASSWORD.
Easiest thing to do is reset the router to factory defaults and then reconfigure it. There should be a recessed button on the back of the router, press it in with a paperclip or something and hold down for about 20 seconds. If it was a wep key, there are utils like wepcrack that can try and scan your wireless net and crack the key for you but really, that would be more work than just resetting and reconfiguring the device.
Wep password
If you forgot the WEP of your wireless network, but you think you left the admin password the default, then you can access the router's configuration utility by opening a web browser to http://192.168.0.1 (or 192.168.1.1, depending on your network) and entering the default admin password. You can then go to the wireless security area and enter a new WEP and this time, write it down! :-)
Hope this helps!
1helpful
Linksys WRT160N - Security Key
connect your pc via cable to the linksys and type 192.168.1.1
username is admin and password is also admin
try to look for wireless settings or wireless security settings and you should have your answer.
if you still have issues, please post back.
please rate the solution if your issue gets resolved, it makes it worth the effort
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
