What exactly do you mean is there No fuel pressure please try and rephrase your question to a whole one. If you have no fuel pressure check your fuel pump see if you are getting any fuel if not it could be a fuse or it could be that you need a new fuel pump. Do you have vapor lock have you tried putting some fuel or ether in your cylinders or fuel injection and seeing if it starts if its vapor lock it could very well break it once it starts. You don't give any information so it is hard to give you any kind of details
My experience has been with later model vehicles, but a bad throttle position sensor most definetly causes this type of situation. Two torx screws, opposite side if the throttle body, should have a three wire plug.
check fuel filter to see if its clogged. (cheapest easiest)
if that doesnt work rebuild carburetor (expensive but fairly simple)
if that doesnt work pull tank if it is low on gas or pull bed if gas tank is full a replace fuel pump (time consuming, hard to do, but fairly inexpensive) I had this problem on a silverado I had and it was the fuel pump.
hi yes you have to remove the gas tank to get to the pump.once tank is out remove ring holding the sending unit.then remove unit replace pump then reinstall in tank then put tank back in. and try to start.
