Computers & Internet Logo
Posted on Nov 07, 2009
I wana know if i can reset my router password without restarting the router to factory settings
Anonymous
Level 1:
  • Contributor 29 Answers
  • Posted on Nov 07, 2009
Anonymous
Contributor
Level 1:
Answers
29
Questions
0
Helped
7355
Points
79
Yes, If you know the routers' administration password, you can log in to the administration settings and change the password. If you are asking if you can change it without knowing the admin password, not likely.
2answers
Forgot my password and can't log on with another pc
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings Hope this helps don't forget to vote
Do not know know password for wireless internet
Hi
Go here and download the manual http://static.highspeedbackbone.net/pdf/Netgear-WNR2000-manual.pdf
You will need to reset the router or change the password in the router 1. To change the password, goto Internet Explorer 2. In the address bar type 192.168.1.1 3. Press enter key 4. YOu should see a box with username and password fields. 5. username is admin 6.password is password 7. These are not the wireless passwords but the access password to get in the router. 8. Once in the router interface on Internet Explorer; goto the wireless sections and change the password there.
To reset the router WARNING: This will reset all the settings to what it was like when it came fresh out of the box. You may need to know some other settings. Restoring the Default Password and Configuration Settings You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 5). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Failing this, please refer to the manual, page 29 onwards
All the best now
Phil
I'd forgot my wireless password, help
In case you have forgotten the password,
ALL YOU CAN DO IS TO RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. It may be a push botton or else use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
HOPE IT HELPS...Let me know if you need any further assistance
CreativeTECH
I fortget the password plese tell how to get recover the password.
CreativeTECH
Lost password,how do I change password
You may reset router to factory setting from the reset button on the back side of the router. Use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
CreativeTECH
5answers
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Wireless light is not on
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot. If the wireless router fails to restart or the power light continues to blink or turns solid amber, the unit may be defective. If the error persists, you might have a hardware problem and should contact technical support.
16helpful
5answers
Sweex Wireless Router Model:LW050v2 Ver2.0
hello , please follow these steps --> After the reset , the router will restart and the factory settings are reloaded & the computer will lose connection with the router for around 30 seconds. After this the router can be accessed through its default IP Address. (192.168.50.1).
Method-1 :- To reset the router , press the reset switch , press and hold the button or reset switch while you switchon the router again. After switching on the router press and hold the button another 10 seconds , then the router will restart.
Method-2 :- Left in the column, click "System Tools" and then "Factory Settings". click "Restore" to start the reset. A message appears , click "OK" to continue.
This solves your problem... plz do rate me..
2answers
Router Password
There are only two ways to restart a router.
1. Go onto its settings and reset it to factory settings.
2. Hold the restart button for 15 seconds. (try sticking a pen in there, and see if it does anything.
Soultion (if nothing works)
Get a new router.
Grand Canyon Tech
Grand Canyon Tech
