Hitachi 50V715 50" Rear Projection HDTV-Ready Television Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
50v715 hitachi..the tv was on doing fine then it went off and the 2 red lights blink. What can i do to fix it?
Anonymous
Level 2:
Scholar:
  • Expert 101 Answers
  • Posted on Nov 07, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
101
Questions
Helped
22390
Points
151
If is the lamp and temp light on the front panel, then it could be that the bulb (lamp) needs to be replaced. Make sure you buy an original replacement lamp (phillips) they are supposed to last longer. There are also videos on you-tube that show you how to replace the lamp. Hopw this is helpful.
1helpful
I have a 50V715 purchased in 2004 no picture.
U used this tv alots?About 4 or 5 hours a day?It time to change the projection bulb,the live span of the bulb are over.
When i try and turn my tv on the power light blinks blue and the fan and lamp light blinks red the everything turns off after about 30sec can i fix this myself
Hi, Does the set come on for about 30 sec.? I had a 50V715 hitachi, it came on for about 30 sec. then shut down and then it would repeat the process. After about 3 wks and alot of other pain, it turned out to be the lamp was weak. Replaced the lamp and all is great! So... it could be your lamp is going bad. Hope this is helpful.
1helpful
Hitachi 50V715 power on/off problem
I would check to see if any of the fans stop turning or don't turn when set turns on. They do have sensors monitoring them and the set will shut down if they are not turning. I believe there are three fans around the chassis.
Hope this helps,
Skyassoc
1helpful
TV will not turn on. Lights Blink and hear noise
Have you replaced the lamp ? Make sure the door cover is closed good because there is a switch that is made when the door cover is put back on. Also you could have a bad ballast board or bad power unit board. Just a thought...... Hope this is helpful.
2answers
Our Hitachi tv turns on okay but the picture on comes in for 2-3 seconds and then the screen goes black. Last night the tv work just fine but this problem started today as I turned the tv on to watch...
I don't know what model you have,but... I have a 50v715 and it was doing the same thing and it turned out to be the lamp. So if you have not replaced the lamp in a while then it could just be it time. Hope this is helpful.
RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
2helpful
Power light blinking continuosly
First off check your lamp or replace it. You can never have too many lamps..........in the last minutes of overtime ! Are you kidding Me! If lamp doesn't work, you will need to find qualified servicer. Try craigslist or tv repair in yellowbook
Craig www.classtorations.com
TV won't turn on with remote
Unplug your set from the wall and wait a few minutes. This fixed the same issue on my 50V715
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
