My LG Studioworks 563N monitor suddenly turns off and the green light becomes off (black), but, after afew minutes it again turns on. I use WinXp OS and mercury motherboard. also, I have set the monitor to 1024*768 pixel display could thse be some problem? plase help, thank you in advance.
i use to plug out and plug in the monitor. it works fine. but time it takes to switch on is annoying :(i use to plug out and plug in the monitor. it works fine. but time it takes to switch on is annoying :(
when the monitor goes off..did u try to give a thud or **** (like slap)..if not try this for once..post comments..i/we hv the solution in either way....when the monitor goes off..did u try to give a thud or **** (like slap)..if not try this for once..post comments..i/we hv the solution in either way....
You can't post conmments that contain an email address.
You can try this. Open the cover (Unplug the monitor and leave at least for 30 minutes before doing this). See whether dust is there. If there is dust, get a 1" paint brush and gently remove the dust with the brush. Always sweep the dust away from the unit. If black dust is present around certain cables and around the flyback transformer (that black box covered with aluminium plates), use a soft cloth to wipe them (do not wet the cloth).
*Make sure you dont turn those rings on the back of the tube while wiping the the dust.
After cleaning the dust, replace the cover, connect it to the PC and check. You will have a brighter picture!
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Plz check your monitor's vga cable for ok .I think there is problem in 1,2,3 no pins wires continuity.If it is ok then check components thats are connecting these pin to video amp. ic on crt neck.If they are ok then change video amp. ic with new one.Hope this solution works otherwise i am always ready for help
Is there anything going on in Control Panel, Power Settings? Such as an auto off? Sometimes getting the monitor to come back on after it goes to "sleep" can be tricky. Usually a keyboard stroke works better than mouse movement. It almost sounds like a hardware problem and I would contact the manufacturer and see if it's still under warranty. I'm assuming the PC it is connected to isn't going off?
