Technics SL-1210 Turntable Logo
Posted on Jan 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pitch problem I have a pair of technics ones a mk2 and the other mk5, the other day i thought i have got a problem with one of the turntables something to do with the pitch as i would be mixing 2 vinyl that i had mixed before perfectly and this time 1 was goin faster than the other so i did a test as in i mixed 2 tunes and they were perfectly mixed (both decks pitch was on 0) and then i swapped the vinyles over so they were on the other deck 2 wat they was on and then i beat matched them and the mk5 turntable was going faster so i have got a problem with that turntable and i dont no how to resolve this problem. any help would be much appreciated
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 382 Answers
  • Posted on Jan 14, 2008
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
382
Questions
0
Helped
159720
Points
449
Check it.
http://www.repairnyc.com/
These guys are authorized technics service.
1 Related Answer
Anonymous
  • 382 Answers
SOURCE: Problem with pitch on my technics
You may have to recalibrate the motor. These guys are pros.
Check em out.
Technic 1200mk2 pitch problems
Check for bad solderings on Q201 and surrounding areas.
Resolder IC101 and IC201. If that doesn't help, Q2 and Q3, both 2SD637R, could be broken. If that doesn't fix it replace the electrolytic capacitors. Cheers john. Styluscity
Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me [email protected]
2helpful
2answers
After mixing for a while the turntable (1200 technics mk5) starts to lose the pitch or the record starts jerking up near the -5 or -6.
hi! there is a problem inside your turntable (on the main board) check the components  TRANSISTOR    Q2, Q3,  ZENER DIODE   D3..
CHANGE IT IF POSSIBLE..
Turntables lags on pick up
I have the same exact problem with one of my 1210 MK2 turntables. It seems like the motor is too slow now. When I hit the start button or release the record, it takes much longer to speed up to the normal speed than my other same exact turntable. I don't think it has anything to do with the pitch slider. Please let me know if you find out what the problem is thanks!
2answers
PITCH CONTROL PROBLEM
The reset button disables your pitch control and allows the turntable to rotate at TRUE "0" (zero). FYI, these turntables were NOT made for DJing. They were made for radio, studio, and high end home use. They became DJ turntables, because they were perfectly built for the trade. So, the pitch reset button is more of a function best suited for radio stations or a producer who needs to record or play at a true zero speed.
Now, on to your question...
More than likely you just have to calibrate your pitch control. There are various videos on YouTube on how to do this properly. Just do a search CALIBRATING 1200s or similar. FYI, all the Technics SL1200/1210 MK series are the same inside. MK2, MK3, MK5 - so don't worry if you only find videos on calibrating MK2's or MK5s - works the same on all the models.
- TERMiNAL OPTiC
www.DJPROLAB.com
2helpful
Pitch LED not working
LED probably burned out, or installed reverse (+/- reversed) - Or, you installed a clickless (MK3/MK5) pitch control in an MK2 turntable.
Did you do this yourself? Or did you have this professional done? If professionally, and the LED does not work, ask for your money back! This is electronics repair 101!
If you did this yourself, then more than likely you installed the LED backwards. The longer lead is the positive lead. If the LED did not burn out, you might be able to just remove it and switch it around. If it does not work, then it probably shorted (more than likely). Also make sure that none of your solder is touching. This could cause a bad short to your entire turntable. So you want to becareful.
If you need any further assistance, feel free to give our service dept a call. We are masters with the 1200s, and fix over 300 a year! 1.866.668.1596 ext 1
- TERMiNAL OPTiC
www.DJPROLAB.com
SL1210 MK5G PITCH REMOVAL ?
The fader for the M5G's are the same as for the MK5's. As for cleaning, you will have to do it like you did with the MK2, and go from underneath.
DJPROLAB
Check em out.
Torque Problem
They actually need to be "broken in". The mk5 uses a different pitch board, allowing you to reverse, pitch up and down to 16, and lock and unlock the quartz. The mk5 is more precise, so its also more sensitive. Notice the notches on the turntable shaft behind the tonearm weight. The mk5  is just make to be finer calibrated.....your decks are fine, and more so probably your mk2s as well.
Oh and also, the infinite lubrication used on technics that was developed in the 70s is no match for the formula developed in the late 90s. Slick!!
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
