Are you possitive that your iR3300 has printer kit installed. That series of Canon copier comes with NIC installed, but the print DIMM and network firmware is an additional option that needs to be installed. If I remember correctly, there is a way to display the firmware levels...you would see iR3300n (network).
When configuring an address for the printer, the IP configuration might look like (just an example):
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
It's important to note that even though you are not using any IP addresses in the default range for DHCP, the Subnet Mask and Default Gateway addresses will be THE SAME.
If you have another device on your network that will be assign a fixed address, you would use for example:
IP Address - 192.168.1.3
For any other devices, just increment the IP address by one, 192.168.1.4, 192.168.1.5, etc and use the same Subnet Mask and Default Gateway.
Thanks for your help
I have just realized that switching off and on the printer fixed the issue.
