Samsung WEP301 Bluetooth Headset Logo
Anonymous Posted on Nov 07, 2009
I need to put my samsung bluetooth (wep 301) in discoverable mode
Anonymous
Level 3:
President:
  • Master 632 Answers
  • Posted on Nov 07, 2009
Anonymous
Master
Level 3:
President:
Answers
632
Questions
0
Helped
276437
Points
2196
Whenever you connect your bluetooth (BT) headset to a BT device:
  1. Set the BT device to search for other devices.
  2. While the BT device is searching and the BT headset is off, press and hold the call/end button on the BT headset until it's light is constantly lit and the BT device finds it.
  3. Enter passkey 0000 when asked.
Hold to put the AACRD50CKE bluetooth model in pairing mode
Make sure iPhone is discoverable. Power on the bluetooth device without letting go of the button for several seconds.
26helpful
2answers
How to use bluetooth headset in samsung corby???? plz plz help me
1. Just activate the bluetooth in your mobile.
2. Put your bluetooth headset in discovery mode (for this you may need to press the ON button in your headset for more no. of secs around 15 secs) . Please read the user manual of your bluetooth headset to know about how to put it in discovery mode.
3. After that, search for bluetooth devices in your samsung mobile.
4. your headset should be detected in your mobile. If not, still your bluetooth headset is not in discoverable mode. you have to turn it on and try again.
5. If listed in your mobile, select it and it may ask for Passcoe. Provide 0000 as passcode. Thats all now the bluetooth headset is connected to your mobile. If passcode is not accepted, then please do refer the device manual to know about that.
I hope this is useful to you.
Thanks
12helpful
My samsung wep 301 will not pair with blackberry 8330. In the desktop manager, the check box to enable bluetooth support is greyed out. Windows 7 BB Desktop 5.0.1 Samsung WEP 301 Blackberry 8330 I'll take...
Please rate. This is how we (advisor/problem solvers) get people to know...we know what were doing. Thanx
1.First make sure your phone is off. Do this by pressing and holding the Multifunction button (the one that flashes blue) for 4 seconds. For "OFF" it will flash blue and red along with a series of 2 tones. Then will stop flashing. For turning "ON" hold multifunction button for 4 seconds and it will flash BLUE 4 times and 1 tone indicating it is on. It will continue to flash every 3 while in stand-by mode and every 8 seconds while on a call. 2.Set your phone in "Discover mode" make sure you look at your manual on how this is done if don't know how. Usually found under Bluetooth settings. 3.Making sure your headset if off. Press and hold the Multi-Function button until the indicator light turns solid blue (hold for approximately 8 seconds). THE MULTIFUNCTION BUTTON WILL BE LITE ONLY HALF BLUE INDICATING PAIRING MODE. 4. You phone will find and ask to pair. Press confirm/OK and enter "0000" 5.If pairing successful, light will flash blue 10x rapidly before going to flash every 3 seconds. IF UNSUCCESSFUL LIGHT WILL REMAIN ON, AND YOU WILL HAVE TO RE-ATTEMPT.
How do you get bluetooth to work?
In the bluetooth menu turn the function on, next turn on discoverable mode. Press and hold the power button on the bluetooth until the light turns on steady, usually 10 seconds or longer. Next on your phone select "search for a new device". It should find the bluetooth. It will ask for a PIN number enter 0000 (four zeros) then select pair. It should automatically connect every time after this. Be sure to turn the discoverable mode off so other devices cannot access your phone. Good luck to you
11helpful
How do I pair my WEP 200 samsung bluetooth to my phone blackberry phone
Your phone MUST have the bluetooth on and discoverable. When it is press and hold the power button on the WEP200 until the light turns on steady should be 5 to 10 seconds. With this done, use your blackberry to search for a new device, should be in the bluetooth menu. It should find the headset. Your phone will ask for a password enter "0000" (four zeros) then press pair or enter. It will take a few seconds to connect. Your phone will automatically connect to this headset when you power it on. Don't forget to turn the phone back to un-discoverable when done. I hope this helps.
1helpful
How to pair the device
Hi
You can pair device through bluetooth by allowing your phone in discoverable mode while your bluetooth is on.
Note: Both the cellphones should be having a bluetooth and should be ON as well as should be in Discoverable Mode.
Regards.
5helpful
Jabra BT3030 Device in Discoverable Mode?
Read the users manual(google is your friend)
But in case they drop support soon, turn the beastie on, press and hold the Vol+ and Answer Call buttons till the "on" light goes solid. You're now in discover mode.
Can't bond Samsung bluetooth(WEP 200)with my Motorola A1200 Ming
Try this (from the manual)
2 Press and hold the Multi-Function button until
the indicator light turns on in blue
(approximately 8 seconds).
Top Samsung Radio Communications Experts
ZJ Limited
ZJ Limited
Jean Thiebaux
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
