To program the recording by time and channel, press Prog then press Start +/- (the left-most +/- button below the number pads). You should see the time and channel blanks. Continue pressing the Start +/- button until you get to the desired start time. If you press and hold the Start +/- button, the time will advance by 30 minutes. To set the Stop time, press the next button to the right (the Stop +/- button) until you reach the desired end time. Use the next toggle button (to the right) to set the Date for the recording. Use the Channel +/- button (the right-most button in the row) to set the channel to record. Set the tape speed with the SP/EP button below the Date toggle. Then press Prog or OK to save the recording. This is in the manual under Express Timer Recording which starts on page 42 of the manual. I found the manual here: http://resources.jvc.com/Resources/00/00/99/LPT0024-001B.pdf .
I hope this helps.
SOURCE: Instruction Manual JVC HR-J425
You need the remote working to get at the on-screen setup menus. make sure the remote is set for the VCR (VCR button) and try the menu button. Are you sure this is the right remote for the VCR. May have to get a new remote. Make sure it is a universal that has a MENU button.
SOURCE: JVC HR-S5902U / HR-S5912U S-VHS VCR POWER PROBLEM
Same problem with my HR-3911U after a power spike. Cracked open the box and as I suspected the fuse had blown. Removed fuse, plugged in and tested across connectors, 115v ac good reading. Replaced fuse (1.25a 250v) plugged in and nothing. The deck electronics had fried. Keeping for spare parts such as head and transport mech.
Time to get a new one and a better surge protector. My UPS logs show a 1200+v spike the day it died. We had storms all around us and thunder in the distance, but nothing close by and no rain, but the spike still made it to our inadequate surge protector.
I've read a lot of forums where other JVC owners have experienced the same problem. It appears to be inherent to these JVC Vcrs.
G
SOURCE: Lost manual. Cannot get
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
