Please help..
I was cleaning the electronic pad and must have hit to many at the same time while cleaning...error code 5A6 bath or 6ath...nothing works..how do I reset or fix...
What is the complete model number of your unit?
5 Jan 08 I spent more time trying to fix this issue...I pulled the stove out already...pulled the plug..waited a few...and when I plugged it back in...same thing. Finally, called the establishment where I bought my Maytag. I explained the problem...he said...hold the timer/clock button down for a couple of seconds...PRESTO!!! The keypad cleared and returned to normal.
I was trying to set the temperature and timer for our dinner to bake...must've hit them too fast or ??....Now I can't get the oven to work. I have tried holding buttons but I just have this straight vertical line on the left. Whenever I touch any other button, it will give me a temp of whatever number on the keypad I have touched. For example, If I hit the number 9, it'll punch in 999 Degrees....hit 5, it'll be 555degrees but the oven doesn't come on, etc.. How do I clear it?
Holding buttons down, doesn't change anything.
oven would not start? keypad lockedup, indicated sabath, online instructions said to press and hold the clock button nice job, did the trick. THANKS!
held timer and clock down no luck. unplogged from power , flashes held again no work
