Looking for a Service Utilities floppy disk for a Compaq Presario 2100. I replace the display and found out that I need to use this disk to reprogram the EEPROM
Access: http://www.compaq.com/support
and search for 'Presario 2100', then click on 'Device Drivers'.
SOURCE: removal
The Presario 2100 is a laptop. Laptops don't have towers.
Refer to this manual, page 50:
http://h10032.www1.hp.com/ctg/Manual/c00246219.pdf
SOURCE: forgot bios password on a compaq presario 2100. is
If you are familiar with dissembling and assembling laptops, that's not a big problem, since some laptops have bios battery attached. In this case just remove the Battery and wait for 5 mins and reinsert the battery then all then there'll no more problem with the password. Or if you can do this at this juncture, you can try this article http://www.pwcrack.com/bios.shtml Good luck.. If this helps, please let me know.
SOURCE: i don't have any cd's
You will have to restore all of your programs to there default value
Rather than doing them individually
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
SOURCE: need to reformat the hard
I would suggest you to look at this link, previously, it
help to bring back my note book to its original condition.
