NEC Versa VX Notebook Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not start
I have a NEC VERSA P570/M370 laptop. It runs Windows XP. Upon starting up, the first screen displays, NEC Logo with writing on bottom of screen displaying, F2 to enter BOIS Setup and F12 To Boot On Network. It then shows a second screen. It is a black screen but displaying in white writing with words:Starting Windows 98...
Microsoft(R) Windows 98
(C)Copyright Microsoft Corp 1981-1999
C:> . and a white curser is flashing
It stays on this screen and will not proceed any further
Can you help please?
Alex Howard
Level 3:
  • Master 484 Answers
  • Posted on Nov 07, 2009
Alex Howard
Master
Level 3:
Answers
484
Questions
Helped
124197
Points
1243
How old is o you know whether the memory chips are still good? Is there any way you can take these chips to a person you know who can test the memory chips, to be certain that they are still good?
Did you by any chance try to upgrade theletters and numeric designatio memory recently and, if so, did you get exactly the sane memory chips as you had in the PC before? Down to the exact same letters and designators on the chips, so that they are all the exact same?
All you need are mis-matched chips and your computer is not going to work. If get around, it may seem a simple thing to get wrong, but if you do get it wrong, you can simply blow it away,
Anonymous
Level 3:
President:
  • Master 2,600 Answers
Anonymous
Master
Level 3:
President:
Answers
2600
Questions
0
Helped
1018052
Points
8362
Try this fix...you will need your windows installation disc for the fix.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Num keyboard not seen with NEC-versa-M370 running ubuntu 10.04
I have installed the pack numlockx, activated it with the procedure described on ubuntu.org. Then by making CTRL SHIFT VerrNum (ubuntu.org procedure), the numeric keypad that had been inefective for one year began to work again...
1helpful
I have a nec m370 versa laptop and my wifi light will not come on no matter how many times i press the wifi button . the bluetooth icon lights up alright how do i get it to work as it used to work fine?
please check the device manager in the control panel or right click My Computer and hit propertys then select device manager.. see if there is a conflict with the card.. if the card is not listed please power down unit and look on the bottom of the laptop where the wifi card is located and check to see if it has came loose......if so secure and reboot otherwise card may be bad... thanks
please vote!!
1helpful
How to reformat back to windows vista ?
You need a windows Vista disc. Insert the disc and follow the prompts. I would format the hard drive instead of upgrading do a new install. The best way would be to go into your bios and make sure the boot device order has the cd-rom booting before the hard drive. Then put the disc in and start the computer, when it says press any key to boot from cd hit any key and let it load and then follow the prompts to install.
Upgrade NEC Versa VX
You can insert the Windows XP CD while logged on Win 98 and run a test from the CD. Obviously you need a larger Hard Disk and at least 126 MB RAM to bring XP to a usable speed. You can look for RAM upgrade options in this page.
Connection
Possibly a Failing Battery...
Remove Your Laptops Battery, And Power On With AC Power alone... Then Try Wireless..
If It Works Again Normally, It's Your Battery Going Dead...
5helpful
3answers
Nec versa e2000 laptop
Joelmar, you are incorrect. This model was also sold with xp, I'm typing this on one. If you still have the original Hdd and have not formatted the recovery partition, boot up the laptop whilst holding the f11 key. This will start NEC recovery and allow you to reinstall the system, drivers included. Back up first!
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
