2000 Chevrolet Silverado Logo
Posted on Nov 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Throttle sticks at times when starting out. Hear a popping sound and throttle moves easily then
Anonymous
Level 2:
  • Expert 280 Answers
  • Posted on Nov 06, 2009
Anonymous
Expert
Level 2:
Answers
280
Questions
0
Helped
118857
Points
811
There is a throttle-stop, this prevents the throttle valve getting stuck in the bore, put simply the valve is a perfet fit and if it fully closes it is liable to get stuck in that position, so a "stop" is employed to keep the throttle just a tiny bit open, but without increasing the idle speed, it is similar to an idle-control screw. tighten this a little, so it keeps the throttle a little more open - check this diagram to find the stop adjuster screw.throttle sticks at times when starting out. Hear a - 09aa699.png
Anonymous
Level 3:
President:
  • Master 676 Answers
Anonymous
Master
Level 3:
President:
Answers
676
Questions
Helped
287647
Points
2168
You will need to get near the intake. You will need remove the air hose that goes to the intake. Once removed you will see the butterfly. Use a throttle body cleaner to clean inside and behind butterfly as best as possible. Use a screw driver to hold butterfly open to clean behind it. This should clear up the sticking of the throttle.
1helpful
3answers
97 escort lx will not start, i have fuel spark and timing belt is good it cranks and sputters like its about to start but wont fully turn over every so often i can hear a pop sound when i try to start
Sounds like the timing belt has jumped some teeth. that pop you hear is detonation as the cylinder is firing while the piston is on it's way up.
Oldsmobile intrigue problems
make sure the throttle cable is not damaged and moves easily by disconnecting the cable at the throttle body and move the cable back and forth it should move easily and no restriction in movement. if this is good then you can try to clean the throttle body as it gets dirty inside and can cause the throttle to stick.
Backfire at idle. no power can not drive
If this is a "Cam Phaser" style engine, it may be the problem. Engines of this type used a part that adjusts the timing on each half or bank of the motor. When a "cam Phaser " sticks out of position, one side of the motor is timed different than the other.
Look up articles about your motor by size. The 2004-2008 years were bad for this problem and there were recalls with limits.
2answers
My truck starts every time it just takes a couple times to start some times i have to pump the gas some times and it does start some times the first time i turn my key
sounds like your butterfly valve could be sticking you can get throttle body cleaner at pepboys auto zone and take off the tube that goes from the throttle body to the air filter and use a rag and clean the butterfly valve and the black ring around if you move it by hand it should not get stuck it should be free. there is a throttle position sensor on the other side and if it dosent move freely it will not allow the engine to function right let me know if this helps
Carb is sticking.
car and start it up and try to push the gas pedal and it doesn't move. Perhaps it comes free with a bit of coaxing, or force, but, over time, this problem is certain to get worse.Or, far more frightening, you're on the freeway and push the pedal to pass a slow moving truck. When you take your foot off the pedal it doesn't come back up and your car goes speeding down the highway.
Having a sticking gas pedal can be a very dangerous situation and you shouldn't drive your car if you're experiencing these kinds of problems. However, it may be an easy fix once you figure out why it is sticking. The gas pedal to throttle connection is actually quite simple. The pedal acts as a lever that moves the throttle able in and out. The throttle cable pushes a small lever that opens and closes the throttle. Any problems with the gas pedal is certain to be in one of these three parts.
The first step to diagnose the cause of a sticking gas pedal is to remove the breather so you can get to the carburetor or the throttle body on a fuel injected vehicle. Once the breather is removed you will be able to access the cable linkages. Disconnect the cable from the throttle. You can now move the throttle manually to see if the problem is there or if it is in the cable or the pedal.
If the throttle moves freely the issue is most likely somewhere else. If the throttle is the location of the problem you will want to clean that. Depending on whether you have a carbureted or a fuel injected vehicle you will want to make sure you get the appropriate spray cleaner from your parts dealer. Fuel injector cleaner won't get all of the stuff that might be causing problems on a carburetor but carburetor cleaner will leave residues that can damage a fuel
2helpful
I have a 2001 F150 supercrew with the 5.4 engine. It starts easily but will not run in park. It will die in 2-3 seconds but will restart easily. When I used both feet on the pedels and shifted into...
Sounds like an issue with the IAC ( Idle Air Control ) on the back of the throttle body. Some times the plunger that moves to let air in the back of the throttle body at idle get gummed up, and won't move ( or move far enough ).
You will need to take the plastic throttle body cover off to get to it, it is held on with 2 8mm ( 7 or 9 ? ) size bolts ( actually a sheet metal screw with a hex head ).
When my 2001 had similar symptoms the 1st time I cleaned the IAC with throttle body safe cleaner and a q-tip. I rinsed the IAC with 90% alcohol, let it dry and reinstalled it. The 90% alcohol could be the source of the 2nd time I had an issue ( guess it dried out the rubber seals on the plunger ), so I replaced it ( think it was ~ 70.00 new from a Ford dealer that sells part online ).
Here is a picture of where it is located, bit of a stretch to get it out, but easy enough to do.
This is the plunger on the inside that needs to be clean and operate smoothly
1helpful
Cruise control went out on my 2005 ford taurus and my accelerator gets stuck at times. Should I replace the cruise control?
This is a dangerous defect. What you want to do is isolate the Cruise cable from the Throttle mechanism. Then get the Cruise cable away from the Throttle so it can not jam the Throttle accidentally.
With the engine OFF use your hand and move the remaining Throttle mechanism and feel for sticking or roughness in the control. If you feel binding, start removing the connection of the Throttle cable and work your way through all the moving parts like a Butterfly flap on the Airhorn, the TPS (throttle position sensor) and so on until you find out what is rubbing.
It is possible that the Cruise was disengaging because the Throttle parts were binding. If disconnecting the Cruise eliminates the sticking throttle, then all the problems came from the Cruise control cable or the Cruise Box. Once you have made a thorough check of the Throttle you can blame the Cruise for your problems and replace the parts.
1helpful
Gas pedal sticking. requires more than normal pressure until car starts moving
I had same problem on my 2004 lesabre, I waited until it was stuck and opened the hood and pulled on the throttle by hand very easily and could feel it sticking there, so I sprayed carb cleaner on the springs and around and through them. This loosened it up right away and have not had any trouble since, I did not spray anything into the throttle body, Good luck
2answers
My 97 blazer wont start or turn over, now my key is stuck
Shake the shifter or press up past park and it will free the key. The pins in the ignition get easily stuck on GM vehicles. I would also assume that you may have a short or bad negative ground cable from motor to body, door switch wiring, or radio. Otherwise your altenator may be bad
3helpful
2answers
''Choke'' warning light on an '81 Corvette
have you checked to see if the choke is on? this light lets u know the choke has an open circuit, it is heated by stator wire from the alternator.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
