Question about T-Mobile Sidekick® 3 Cellular Phone
I turned the phone on and there is nothing on the display. I can hear sounds but nothing shows up on the display. No menu...nothing...just a blank screen. This is on a Sidekick 3.
    President:
  • 625 Answers
IF you sidekick 3 screen is blank then the lcd needs to be replaced. Replacing the Sidekick 3 LCD screen is pretty easy and cost about 25 dollars if you buy it from ebay.
Here is a guide for it Sidekick 3 LCD Flip Screen Replacement
and here is a link to the screens
Buy a replacement Sidekick 3 LCD screen.
Posted on Nov 09, 2009
SOURCE:
The front screen of my Nokia 2720 is just blank, how do I get to work
The micro ribbon wire may be damaged if its blank if the phone is old this may be the case opening and closing breaks the ribbon wire after time. If it is new return for replacement. also in menu, phone, display is where all adjustments are.
Apr 06, 2012 | Nokia 2720 Fold Cell Phone
Hi! I have a problem with my Nokia 7370 : the screen is blank and nothing is happening. I tried switching it off, then on again, but no luck, I have nothing but a blank screen. Even when I plug the battery...
can u hear any sound like nokia tune which comes when u turn on your mobile? It could be because your display is damaged or not working so please visit nokia showroom and they will help you.
There can be several things which can be reason for blank screen like:
1. Your display is not working
2. Battery of mobile is not working.
3. May your mobile is not charged and charger which you are using is not working. Try charging with some other charger of nokia same pin.
4. It could be software issue. Please update software in your mobile.
60% it could be a display issue.
Jul 21, 2010 | Nokia 7370 Cellular Phone
My apple powerbook display is just showing blank. I had turned the powerbook G4 and when I went to restart it the display would not show anything. I can hear the startup sound but nothing on the screen....
Just remove ur CMOS battery and harddisk connection from motherboard. And then try to restart it will give u a msg no boot device or OS found.. Now reboot and add the CMOS battery and harddisk on motherboard...
Apr 24, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Powers up but black screen shows
1st - Try pressing <Fn> + <BrithnessUP> keys a few times, (on HP <Fn> key is between <Ctrl> key and <Windows> key, <BrightnessUP> key is <F8> key and <BrightnessDown> key is <F7> key. If nothing happens try the 2nd one.
2nd - Plugin external monitor, (type and size doesn't matter). Turn on your laptop. If you can see desktop on the external monitor, your drivers are o.k., The problem is your laptop display, NOT the graphic chip.
Oct 21, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Blank menu display
when you turn on your phone,, do you still receive calls or text messages, or some sounds like the nokia booting up?? if so, the phone works fine only the display, change your lcd
Aug 27, 2008 | Nokia 6233 Cellular Phone
ZENITH TV, no picture
Sounds like the vertical output IC causing the CRTs to blank you would still have audio and on screen display. Try resoldering the vertical output IC.Thats a common problem
Mar 19, 2008 | Televison & Video
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
T-Mobile Sidekick® 3 Cellular Phone Logo
109 people viewed this question
Top T-Mobile Cell Phones Experts
Ekse
Trimesh
Steve Allison
Steve Allison
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
