Re: Lg 26lg30 light blinks red blue wont turn on. When...
You have a bad cap in the power supply
these are can shaped device thet if bad will vent anf put up on the top the valoue is wrtten on the side trplace them and you should be good to go
I have a Toshiba 50hp66 with similar symptoms with the addition of the power board clicking and lights on followed by a long buzz from Y-SUS. Is the communication one way pointing to Y-SUS or bi-directionalI have a Toshiba 50hp66 with similar symptoms with the addition of the power board clicking and lights on followed by a long buzz from Y-SUS. Is the communication one way pointing to Y-SUS or bi-directional
You can't post conmments that contain an email address.
Note: The red LED on the rear will blink when the memory card is not inserted .... The Start REC button should always point up or at the 12 o'clock position for a ...
? 0:43
https://www.youtube.com/watch?v=Q8JG53DU6Rk
Nov 5, 2015 - Uploaded by Gillet Gaming
My TV suddenly started blinking when I turned it on at 12o'clock. ... I was going to use it when a few ...Missing: p
11/7/15 18:05, San Diego, CA, Diamond, 5 minutes, Orange Diamond like .... 8/23/15 21:08, Wildwood Crest, NJ, Diamond, 2 minutes, Hovering red light, ... Diamond shaped brilliant white light with red light in eastern sky at 12 o'clock ..... flashing blue yellow the red at times staying solid red or blue seems to get bigger. 2/27/ ...Missing: p
I can think of 4 solutions....but what has worked for me is unplug it for 10 minutes then power on but dont push anything ....wait a minute for the computer to re-anylize..then go through your set up menu...hope this helps...Replies are appreciated
I would look in the power supply for bulging capacitors, With cheap caps being used these days its not uncommon for faults like this. If all looks ok and all voltages are correct if you have a meter to test them then i would replace the main av board which should correct the fault.
boards and power supply's can always be found on Ebay
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. http://en.wikipedia.org/wiki/Capacitor_plague Please post back what you find.
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
