I have a Samsung Eternity that for some reason will not send multimedia messages anymore. They go to and stay in the outbox in sending mode and never send. I have cleared memory on my phone thinking that was the problem but it's not. The messages are rather small so I know they should be sending. Any ideas?
Your problem is not with the tablet but with the email client. You need to connect the client on the tablet with a valid email account that you have elsewhere. The email account will have details to help you do this.
First of u should know about he limit of attachment, if its ur orgazniation email account then u should ask for the attachement sending policy most organizations r allowing only 5 mb attachment to send, if you r using gmail with outlook then gmail will allow u to send up to 20 mb attachment. before u cancel the message from the outbox u need to cancle the send/recive once that cancled u will be able to easily delete the message from outbox.if you r not able to open outlook u need to close ur outlook from taskmanager , open the process tab and close the outlook.exe session. or you can restart your computer and open ur outlook. u can open ur outlook safe mode to delete that sending file.
1 move the text that can't be deleted from OUTBOX to DRAFTS
2 if you still can't delete it go to SETTINGS-FLIGHT MODE select SHOW at STARTUP
3 switch phone OFF and ON again. select FLIGHT MODE at the beginning. switch phone OFF and ON again
4 select NORMAL MODE if asked. go to DRAFTS and delete that message
My wouldn't either. I went in to "Menu"- "Messaging"-"Message Settings"- "Multimedia Messaging"- "MMS Profiles". I had 3 choices on the next screen... Since I use AT&T I checked 'AT&T MMS" My other choices were "media Net and AT&T IMS" Media net was checked but after I changed it to "AT&T MMS" I was able to start sending pictures and videos.
Hope this helps.
~CherylofTexas~
The D900 series doesn't automatically save messages to your Outbox when you send them (frustrating I know..I have one as well) & there's no way to change this setting by default.
The only way I've found to save messages to your Outbox is to select the "Save and Send" option when sending a text "as opposed to "Send Only".
It's annoying but you get used to it once you're in the habit.
The reason why it is doing that is because you probebly sent to much messages together so it will not know which message to send first so to fix it just go to your outbox and delete them all. Good luck with it!!!
I had the same problem and I read on down and saw someone's phone was stuck in flight mode. I remembered that for some reason, my phone was in flight mode the other day, so I went in and took it off. I realized the problem had been since that time. So, I put the phone back in flight mode and was able to delete the message from my outbox. I put it back in normal mode and now I can send texts. Yes!!!!
i think when it goes to the outbox and stays there go to the outbox and send it from the there itmite save them to the outbox so u can send them through the outbox try to send them and when it says saved in outbox go to the outbox and try to send it again through that
