Question about Lutron Diva Single-Pole Dimmer, White
I have installed a Lutron Diva Single-Pole dimmer, and ran the wiring to the light, but have not installed the light. So I tested the voltage on the wire at the light and got 40V WITH THE SWITCH "OFF". Is this normal?
  • 3,600 Answers
No it means you have a short somewhere in the wireing. disconnect the power unhook the switches and use an ohm meter to test the wires to see if you have contact between the wires, black to white and black to bare ground wire. if it's a three way wire test all of them, if you used tsaoles to hold it in place check where you put the staples in you may find you have a staple ran threw two wires. Or if you pulled the wire and pulled it around a hard corner you may have pulled the insolation off somewhere the above test will confirm this. This is assumeming you are testing line voltage without a step down transformer or any other device in the circut
Posted on Nov 06, 2009
SOURCE:
Switch and dimmer work opposite each other
Refer this issue directly to Lutron. They could have an ineresting explanation!
Jan 27, 2014 | Lutron Toggler Single Pole 600 Watt Preset...
What Dimmer can I use That looks like an OS600 but is for a GU24 Dimmable CFL
Depending on your wiring, as to single pole (one switch location) or 3 way (two switch locations) you can use most dimmers. Leviton and Lutron have similar dimmers, and some specifically for cfl's.
Leviton has Sureslide, Illumitech, True Touch
Lutron has Diva, Skylark, and Lumea
Make sure your cfl is dimmable.
Mar 03, 2011 | Philips Lightolier Onset 600W Incandescent...
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
http://www.lutron.com/TechnicalDocumentLibrary/0301107A.pdf
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
I need to install a diva low voltage electronic dimmer. An incandesent dimmer was previously installed. lights flickered. There are 4 wires on the dimmer. (green black whate and yellow) I know what to do...
The dimmer connections should go like this.
Black from dimmer to black Constant Power In Wall
White from dimmer to Neutral (Whites) in wall
Yellow from dimmer to wire out to light (usually black)
Green from dimmer to BARE GROUND WIRE
May 08, 2010 | Lutron Diva Electronic Low Voltage 3-Way...
Replaced existing Lutron skylark low voltage dimmer
You will need to return the 3-way dimmer and get a single pole dimmer, as the Lutron Skylark series is suspectible to failure if connected to a live circuit first, or misconnected at intial installation. As an electrician, I ceased using these dimmers years ago, due to the rash of call-backs by customers and went with Leviton togglers and have had excellent results.
If you purchased it at a 'big box' store, they will accept the return as a defective item, as they have national agreements with their suppliers to accept customer returns. Just tell them it didn't work and you want a store credit, you can then purchase the lower priced single pole dimmer you need and save some money in the process too.
Hope you find this Very Helpful - best regards!
Aug 18, 2009 | Lutron Electrical Supplies
Lutron skylark s-10p 1000w dimmer. why is one
This video from the Lutron site shows the Diva switch but it is the video for the Skylark single pole switch also. It makes no mention of one wire being a larger gauge and does not differentiate which wire connects to line power and which to load. I do not think the wire gauge makes any difference.
Aug 11, 2009 | Lutron 1000-Watt Incandescent Dimmer...
Electronic Low Voltage Master Dimmer
Home Depot sells Lutron dimmers which are single pole and basic.. www.homedepot.com
Apr 24, 2009 | Lutron Electronic Low-Voltage...
3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Mar 30, 2009 | Lutron Electronics Diva 3-Way Duo Dimmers,...
Lutron Diva Single-Pole Dimmer, White Logo
250 people viewed this question
Top Lutron Electrical Supplies Experts
jdthefixer
Craig Butler
Craig Butler
mikenearman
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
