Question about SkyScan 86742 Digital Atomic Wall Clock
Wont report outside temp , I changed both batteries inside &outside It reports inside temp ,but not the outside.It was working a month ago and suddently wasn't working right. Thanks in advance Jack
    New Friend:
I read the directions on the back and it is working 100%!
Posted on Nov 07, 2009
SOURCE:
Gauge a temp ne fonction pas et fan tourne tout le temp xc70 2006
Turn the temperature knobs all the way hot for a little bit, then all the way cold for a little bit. That's reported to bypass any "interpretation" by the computer/climate control.
Also, go to the dealer and have them read the computer codes from the car. One of the temp sensors could be bad. The climate control depends on inside/outside temp and other data to work properly.
The car will probably have codes relating to this that do not set a "check engine" light.
Jan 13, 2018 | 2006 Volvo XC70
My truck will turn over but won't start
Toyota Tundra Maintenance & Repair Questions - CarGurus
www.cargurus.com > Questions > Toyota > Tundra
CarGurusfrustrated2000tundra asked a 2000 Toyota Tundra 2 Dr SR5 V8 4WD Standard Cab LB Maintenance ... My 2000 tundrasr5 4.7l 4x4 wont start! ... 2008 Toyota Tundra ...won't Start ... Report. rckwll asked a 2001 Toyota Tundra Maintenance & Repair question 2 months ago ... 2002 Toyota Tundra Turns Over But Will Not Start.
Toyota Tundra Questions - CarGurus
CarGurusGet fast answers to your Toyota Tundra questions from experts in the CarGurus automotive ... My 2000 tundrasr5 4.7l 4x4 wont start! Thought wasn't getting fuel because tries to turn over but wont. ... Tundra Dead Battery, How Do I Open The Door Or Hood To Recharge? ... 4wd Hi Light Flashing, But Will Not Engage.
Jan 22, 2016 | 2001 Toyota Tundra
2011 kia sorento won't start in cold
Check the engine temperature sensor. There should be two of them, one that reports it inside of the car and one that reports it to the ECU. The one that reports it to the ECU has likely failed and needs to be replaced.
Nov 28, 2013 | 2011 Kia Sorento
My ge fridge won't keep temp in freezer Or fridge side. We replaced the board 8 months ago .
You may have a sensor the reports information to the board reporting the wrong information and causing this problem. Also possible is the evaporator fan could not be working causing the lack of air flow. At this point I would suggest to have a service call done to find the correct problem. The service person needs to use a laptop to service the unit correctly, this will assure all sensors and fans are running up to speed. If your in the SoCal area I would be glad to help.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 27, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I moved my freezer to the shed 6 months ago as soon as the cold weather hits the freezer has stopped working. The light is on inside and out, defrost timer is working. I?m thinking thermostat or compressor
Freezers & Fridges were not designed to operate in extreme cold conditions. They are designed to operate at room temp. It could be sending an inaccurate temp signal to the thermostat due to extreme low temp outside.
Nov 27, 2010 | Refrigerators
Activity report for fax send 2 month ago (Canon MP830)
Page 104 & 105 talk about the activity report. You can have it print out every 20 transactions but you can also look at the log as a whole report as well. The manual for your printer is located here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804#DownloadDetailAct
Click on Drivers and downloads. Go down to the guides and manuals section. click on this PDF file: mp830_ug_us_v4.pdf
Make sure you have adobe reader on your computer and check out pages 104 and 105. They talk alot about the activity report.
May 28, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Old reports
I'm not sure what you mean by 'restore old data'. If you are trying to re-print a daily report from 4 months ago, the report is cleared at the time it is printed in Z mode, so it is gone now. ---------------------------------------------------------------------------------------------------------
Looking for a Casio TE-7000s manual?
http://the-checkout-tech.com/manuals2/cashregisters/Casio4.php
Mar 10, 2010 | Casio Parts Cash Register PC Desktop
I have a nec i-select m5210.i dont know if the battery is dead or the laptop wont recognise it.if it is dead what is the no. of the battery i need
you can go on ebay and get a battery for an nec m5410, they are the same
Does the battery in an nec m5410 work in a nec 5210? I have an nec m5210 computer and need a battery, it looks like BATTERY FOR THE M5410 may work but i want to certain before i order from ebay HELP!!!!!!!!!!
  • 1 month ago
Report Abuse
1rvtbxww4aaeb_mhf9vk=.medium.jpg by DavidG Member since:07 June 2008Total points:15365 (Level 6) Best Answer - Chosen by Asker Yes they are the same - the part codes SQU-510 and SQU-527 are compatible
  • 1 month ago
Feb 17, 2010 | Computers & Internet
SkyScan 86742 Digital Atomic Wall Clock Logo
639 people viewed this question
Top SkyScan Home Experts
Dave Robertson
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
