Is the tank cracked or is it leaking from the bolts that go through the bottom? If the bolts are leaking shut the water off, Should have a shut off valve behind the toilet, If not possible around your house. Mine is out by the road where the water meter guy can check it. But shut the water off and put 2 new bolts and gaskets through the toilet. Very cheap fix. under $4.00 USD
You need to replace the tank to bowl nuts, washers, and gaskets as well as the flush valve gasket. One word of caution. When installing the new bolts to hold the tank in, place a rubber gasket under the washer inside the tank, and also one on each bolt under the washer underneath the tank. If you omit the one under the tank you may end up cracking the tank when you tighten it down.
There is a rubber gasket between the urinal outlet and the pipe it connects to in the wall.
Pull the bolts holding it to the wall and pull it away carefully.
If it has been siliconed to the way, you'll have to cut it. Swap out the gaskets.
Be careful not to pinch the new gasket.
Ask at your local plumbing supply for the gasket of your particular model. They'll know what your talking about.
Did you try calling or emailing the parts dept. at american standard? I am not sure if they just sell the gasket. American standard parts are certainly different from most toilets. I looked on ebay, not much for american standard toilets. Were you able to remove the four screws and get the sealer under the gasket.? I will do some more research for you and try to find parts. take care, andy
Replace the fill valve. You can pick one up[ at Home dep or Lowes for about 20 buks. Close your angle stop at wall behind toilet. Drain all water from tank then remove supply loine from under tank. Then unscrew fill valve and remove gasket and all. Remember to put gasket in new one. :)
Hard to read you question. No sure what it is but if the flapper is still leaking it may be bcause most brand of fleappers do nto fit American Standard commodes correctly. Purchase a replacement made for American Standard only.
You have replaced the flush valve completely? If so and the unit is still leaking, you may have a small crack in the tank or your just not getting the tank to bowl fittings tight enough. Also, they make two different thicknesses in the tank to bowl gasket. Make sure you are using the thicker of the two. You posted this under the American Std. thread, so if this is correct, give them a call. There could be a recall on this particular toilet due to a flaw.
The hole your refering to is common in the manufacturing of toilets and is generally filled before it leaves the manufacturing. I have repaired several toilets, new toilets, all American Standard, using a good grade of epoxy - not silicone. I used West System epoxy as this is made for marine projects and surprisingly states "toilet repair" as one of the uses of their product. I'd suggest carefully chipping the smooth porcelan around the hole to give the epoxy something to grip. Use a knife or screwdriver to gently chip the edges and make sure the area is dry. Press the epoxy into the hole and give it enough time to cure before putting it back in service. Of course, if the toilet is less than a month old I suggest returning it and getting a new toilet.
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Rear gasket? The one under the tank?
