SOURCE: moving line through plasma and LCD TV's
This is a very common Ground loop problem. The quick cure is to put a 2 prong to 3 prong adapter on the plugs which effectivly removes the ground from the circuit and stops your lines. Have fixed over a hundred TV's since the 60's that way.
SOURCE: no signal when hooked up with a digital cable box
turn your tv to channel 3 and then try 4 one of these should work . Also make sure that you have it plugged in the right coax jack in the back
-Josh
SOURCE: Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
it might be inverter board it is not backlight bulb according to my expertise bcoz once it goes off it dont come back
but u see inverter and CCFL backlight bulb failing symptoms are so same that u cant simply distinguish but i am sure u have one of these two problems inverter is more chance
Kindly rate me well
Regards
Zohail
SOURCE: screen flashing ribbons of color over picture
i think its your cable box. check it carefully.
