Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Dc1804f charger Makita DC1804f charger wil not charge batteries, even a brand new battery. Using the correct type of battery for the charger but keep getting a flashing red/green 'battery fault' light. Is the charger to blame????
  • 350 Answers
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Posted on Nov 06, 2009
SOURCE:
Polaroid rechargeable batteries in duracell charger
The problem isn't the brand of batteries Vs. charger; the problem is the electrical rating of the charger Vs. the charging specifications for the batteries. First make sure that the batteries are the correct type; i.e., nicad, lithium ion, etc. Do not try to recharge alkaline batteries. Your batteries have a mili-amp hour rating either shown on the battery or in the manufacturers specifications that are available on line. Each battery type also has charging specifications. The battery charger is designed to provide a specified charging voltage and current to the batteries and those specifications must match the battery's design. Using the incorrect charging voltage and current can cause the batteries to overheat and even explode.
Mar 18, 2014 | Polaroid I531 Battery (Equivalent)
Dc1804t charger won't charge mdl 9000 batteries. Indicates bad battery (alternating red and green) for even new batteries.
check that you are trying to charge the correct batteries. . The come in 2 types ni- cad and li ion. Most battery chargers will not charge both types because of the different charging requirements.
Nov 26, 2013 | Makita Univ Volt Charger
Makita battery
Check that you have the correct battery in the charger as the charger will not charge any type of battery, only the battery type listed on the panel.
May 06, 2013 | Electronics - Others
Hi, I have repaired 3 Makita 18V 3Ah Li-Ion batteries recently by removing good cells from other faulty batteries. The Voltages are good now on all 3 and they charge/discharge OK on my own charger but...
Some manufacturers put some chip on their battery so it can be identified by their charger. If you use a generic battery often, it will not charge or work properly. LG does this with their phone batteries! So you have to use another charger to charge them.
Jul 07, 2017 | Makita Drills
Hi i have a makita charger that flashes red and green indicating battery is no good but the batteries are perfect they charge fine on other charges an i even tried it with a brand new battery it starts...
there is a problem with the charger and given the age I would take it to an authorized dealer and get a replacement. If you give me your general area I will try and locate one close to you. Please before voting if you need more assistance let me know. Thank you
Feb 02, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Can my makita bl1830 battery be repaired if it does not hold charge anymore
This battery has a known design defect that causes premature failure. The battery is still probably good, but the safety circuit n the battery spuriously locks it, due to a bug. Once locked, it won't charge in the Makita charger (flashing red and green lights). Makita knows about this problem but so far is not actively recalling the batteries. Makita will replace the pack if the charge count is under 150 (some people say 300?) regardless of warranty status, but you have to take or mail it to a Makita Service Center -- the dealers won't handle this unless it's in warranty.
http://www.makita.com/en-us/Modules/Service/ServiceCenters.aspx
If Makita won't fix it, you can try to repair it. If the red and green lights are flashing, the battery is probably locked and cannot be repaired in a way that will let it be charged in the Makita charger (but it can be charged in off brand chargers). Buy a clone charger on eBay for $60 and try it. If it charges, just use it, no repair needed.
Be aware that lithium batteries do lose capacity permanently at a rate of about 20% per year. So, 3-6 years is about the best battery life you can expect - from date of manufacture, so if it sat in the store a while that adds. Makita derates the cells to allow for some shelf life (down from 2400 Mah to 1500 Mah rating).
If the battery is weak, and only gives brief usage, you can replace some of or all of the cells in the battery. These are expensive and worth repairing. See this video:
http://www.youtube.com/watch?v=Z5taguEdlkY
If just 1 or 2 cells are weak, you can replace them with the same Sony 18650 size 2400 Mah capacity battery, green sleeve. The Sony's are not sold retail, and are hard to find other than from another Makita pack or from some laptop packs. If more are weak, you're better off just replacing all of them with new 18650 2400 Mah (or higher) batteries with tabs. Look for Tenergy or other quality brand.
Hope that helps.
Nov 02, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
1,056 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
