Question about Hardware & Accessories
Im fitting a new light fitting i have 3 cables from the ceiling the orginal power cable , the switch cable and another cable to feed another light in my light fitting i have live neutral and loop what wires go where i dont know whitch is the constant live
  • 27 Answers
The grounds go together and perhaps to the fixture.
The white/ neutrals are also all tied together and one goes to the light. Note that one neutral may not actually be that, but is simply one of the pair of wires going down to the switch.
Then you need power connected to one leg going down to the switch (maybe a white one) and the return leg from the switch goes to the light.
Hope this helps. Let me know if not
Posted on Nov 06, 2009
SOURCE:
I have s2-lfsqh-wh 300w 1.5a can this be wired as a 3 way if so how
I doubt it. They are designed for a 3 wire cable going to a ceiling fan with 2 loads. They likely would not design a special 2 in one switch if one side is a 3 way. You will have to have 2 switches and a double box to do the same job.
Feb 24, 2013 | Lutron Dimmers S2LFSQ Dual 1.5A Quiet Fan...
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
I believe my power source is in the ceiling. I just want to wire a light but use a leviton switch and dimmer at the wall. Can't figure this one out. Can you help. There are two red wires, one black and...
Question needs more details. Let me answer as if you have one light and one switch, and one cable coming into switch box from ceiling.
Usually a switch-dimmer combo operates 2 different Loads (lights).
One light is controlled by switch, other by dimmer.
If power source is in ceiling, then one cable enters switch box.
Cable has black, white and ground wires
Old switch had 2 brass screws where black and white wires connect
Black wire brings Hot down from ceiling, and white wire connects back to Load (fan).
Neutral wires are in ceiling box, and not inside switch box, and are discussed.
With new dimmer: Black Hot wire from ceiling connects to dimmer black wire.
White Load wire connects to one of the red wires.
The other red wire goes to another Load, which is unknown at this point.
Add a comment for more free help. Say what cables and wires enter box, and what Loads you are controlling. Also add exact model number so expert can reference manual. Levition instruction sheets and manuals usually have toll free number.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 22, 2011 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
Wiring heater, vent, light with 12/2 and 12/3 from switch to unit. email: lfranklin5@charter.net
I wish we had more information to go on here.
1) You have 2 cables to to the Heat-Vent-Light
One cable is 12-3 and 1 cable is 12-3
2) That's where it's gets fuzzy.
What color wires are on HentVentLight?
Is power at the ceiling box or at the wall box?
What other wires are inside the wall box?
What kind of switch are you installing?
3) With that number of wires, it sounds like power is at ceiling box.
Power would arrive at ceiling box on one cable that has a Hot-black and Neutral-white wire.
4) Start at wall box:
Let's suppose you are installing a wall device that has 3 individual switches, with one switch for each HentVentLight.
The Hot wire from ceiling box would drop down into wall box on a black wire, and this wire connects to brass screw on switch.
Wire going to heater connects to one of the silver screws.
Wire to fan to another silver screw
Wire to light to another silver screw.
5) Work at ceiling box:
Let's suppose your HentVentLight has 4 wires: Black for light, Red for fan, Blue for heater, and White Neutral.
The white neutral connects to Neutral wire as described in #3.
Black, Red and Blue connect to each of the wires that come up from switch.
Add a comment for more free help, and fill in the missing information.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 01, 2011 | Broan-NuTone FAN CONTROL SWITCH
I want to mount a simple ceiling light. The electrician used a 3-way cable (white, black, red and ground) because initially we wanted to mount a ceiling fan with light. I tried to hook up the fixture,...
The red wire is probably the switched leg to the light.. You can verify this by turning the power to the circuit OFF at the circuit breaker, then pull the switch from the box. Post back if you need more assistance.
Jan 17, 2011 | Hardware & Accessories
I want to add a light in my room which is apart of the upstairs lighting circuit. The only problem that I have is that all the terminals within the celling roses in the upstairs lighting circuit are being...
The problem is that you need to understand that the red and black wires may not be power and return. The main red line is broken at a point and a new cable run to the light ( red + black) or (blue+ brown) this is merely the switch circuit fore that light. So if you mistake the two points it may be that what you have is red+red to your globe. ( Is that clear?) you would need to find the common black + the red to take power to the Red+black to your new ceiling rose, but breaking the now new red wire somewhere and joining in a new red_+ black that goes down to the switch
Use a power checking device as sometimes in some roses where multiple circuitsw feed fom Black and Black can be live
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Electric Door Light Switch
Light will not shut off on fixture (replacement of ceiling fan)
One of the two cables in the ceiling box is power and the opther is a switch leg .. what you need to do is connect the two black wires together at the ceiling, connect the white power wire to the white fixture wire ,.,. connect the white switch wire to the black fixture wire .. put some black tape on that white to make it legal .
Sep 27, 2009 | Hampton Bay 52 In. Black Huntington III...
Following the purchase of a new home I want to install a new light in one room. The new light fitting has the basic connection terminals for Active, neutral and earth. The existing light on the ceiling has...
please remember to turn the power off when you are doing this. the extra cable is probably a looped or joined cable. put it in a connector or solder it with tape and leave it behind the light fitting or in the terminal block. connect the same cables up in the active, neutral and earth. like for like. make certain the power is off when you do this.
Sep 25, 2009 | Electrical Supplies
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
New fan light running continuosly
lets see if i can help you out here, okay . Red is your hot power wire, Green is the ground which is screwed to mounting plate, black is negative, meaning no power.... connect your wires by color Red to Red , Black to Black , And if there is a green coming from the ceiling connect to mounting plate of fixture or vise versa. Remember to use eletrical scew caps, on all connections and do not leave any wires uncovered. Basically all your doing is a seperation of a wire from wires as you seperate a wire cap it off. then move to the next set and do the same. red to red black to black green to mounting plate . YOU WIL NOT BLOW ANYTHING UP IF THERE IS A WRONG CONNECTION, if all wires are of color follow these steps, if no color switch one wire try switch and vise versa YOU can do it
Jun 02, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Hardware & Accessories Logo
93 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
