Nokia 6310i Logo
Posted on Nov 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nokia 6310i - Low and No signal
After dropping my Nokia 6310i the network signal has dropped very low, most times dissapears so failing to contact the network. Can this be repaired by a keen novice, a specialist or is it scrap ?
Regards
Brian Jones
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Nov 06, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
3047
Points
16
It's possible that you could fix it, but not entirely likely. It depends on whether it's just a bent antenna connector or if a circuit board is broken.
Some phones have a small spring-type piece that makes contact with the antenna. If this is merely bent, and not making a great connection, you might be able to coax it back into shape and that might fix your phone. Otherwise, it's probably beyond the ability of an amateur to repair.
Anonymous
Level 3:
Guru:
  • Master 312 Answers
Anonymous
Master
Level 3:
Guru:
Answers
312
Questions
0
Helped
111011
Points
1120
Check signal strength in other phones if that is good Please give to nokia care for servicing It will get clear...Hope this will help you....
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1714
Points
U have dropped it and the signal dropped ,now throw it up and the signal will go up
Anonymous
Level 2:
  • Expert 100 Answers
Anonymous
Expert
Level 2:
Answers
100
Questions
0
Helped
59392
Points
281
The internat part are need to reblow.
Unlockme
Do you need network unlock password[code]?
To get this password[unlock code] for your Nokia 6310i at low cost visit Unlocking4U.com and unlock it.This is the easy,safe,fast and permanent unlocking method.
Jun 03, 2013 • Nokia 6310i
Low volume Nokia 6310i
i guess problem is in your profile setting. you have unknowingly changed it. Reset Factory Settings.. this will make all your setting default.
Nov 23, 2011 • Nokia 6310i
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
NOKIA 6310i is restricted, i need code
Yes You can get that easy,You can just Visit the website
http://www.superunlockcodes.com/nokia-6310i/rs12wp9/ buy the Nokia 6310i restriction code at low cost.
Jan 27, 2011 • Nokia 6310i
3helpful
2answers
My N79, got wet. Only Network connection problem.
clean your phone with alcohol,thinner or ipa liquid. Give more attentions to signal section parts,especially to water damage parts.
3helpful
2answers
Nokia 1600 is dead how to repair it
If your phone appears to have problems with power, the problem may be with the phone, the battery, or the charger.
  • The first thing to try is to connect the phone to its charger. Connect the charger to a power source, wait for a few moments, and then try to turn the phone on.
If the phone still won't power on, please perform the following checks:
  • Fully charge the battery according to the instructions presented in the user guide.
  • Remove and re-insert the battery according to the instructions presented in the user guide.
  • Check that you are using a Nokia battery and charger compatible with your phone model. You can check compatibility from the Battery Compatibility Chart and Charger Compatibility Chart.
  • If you have access to another battery and charger of the same type as yours, try substituting them to determine if the issue is with the phone, the battery, or the charger.
If you are unable to test your phone or it still won't power on, please bring it to the nearest Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone is always low on power
If your phone appears to have problems retaining power, the problem may be with the phone, the battery, or the charger.
  • Check that you are using an original Nokia battery and charger compatible with your phone model from the Battery Compatibility Chart and Charger Compatibility Chart. If your battery features a hologram label, you can authenticate that the battery is an original Nokia product with our Check Your Battery service.
  • Even high-quality batteries like Nokia's will eventually lose power retention capacity. If it is time to replace your battery with a new one, be sure to purchase an original Nokia battery from an authorized Nokia dealer.
If you are unable to test your phone, charger, or battery or need further assistance, please bring them to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My calls break up/are dropped
Dropped calls or low sound quality during calls can result from low signal strength or momentary gaps in network coverage, either at your end or the other end of the connection.
In most cases, your operator or service provider is the best source of assistance with issues regarding signal strength.
  • Signal strength is indicated by the signal indicators at the left side of the phone's display, these indicators move up as the strength of the signal increases and down as the signal decreases.
  • To increase your phone's signal strength, try moving your phone slightly, or move towards a window if you're calling from inside a building.
If you continuously experience low signal strength in a certain area, it may be that network coverage is insufficient there. Your operator or service provider can provide you with more information on network coverage.
If you believe that the problem may be with your phone instead of the network, please bring your phone to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone won't ring
Please try the following troubleshooting tips:
  • Ensure that you phone is on and that there is sufficient signal strength.
  • For some phone models, if there is a headset attached to the phone, it will not ring through the speaker, only through the headset. Detach the headset and retest the phone to determine if that resolves the issue.
  • If the phone's profile is set as "Silent", "Flight", "Online", or any other profile where ringing is silenced, it will not ring. Change the profile to the "General" or "Normal" profile and retest. Instructions for checking and changing your profile are included in your user guide.
  • Ensure that a ring tone has been enabled and the volume is not too low. Instructions for adjusting volume and selecting a ring tone are included in your user guide.
  • If call divert is activated, your calls may be going straight to voice mail without your phone ringing. Instructions for activating and inactivating call divert are included in your user guide. For assistance with voice mail, please contact your operator or service provider.
If your phone still won't ring, please bring it to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone won't send/receive messages
Email, text messaging, and multimedia/picture messaging must be supported by your contract with your operator or service provider. In addition, your phone must support these features and have the correct settings.
  • Check the types of messaging supported by your phone model. You can find this information in the user guide. Look for the terms SMS for text messaging and MMS for multimedia (picture/audio) messaging.
  • Contact your operator or service provider to check that email, text messaging, and/or multimedia (picture) messaging are included in your service contract. Also verify that roaming is supported when you are not within your home network.
  • Install messaging settings for your phone. You can download settings for free from our Setting service.
If you are still unable to send or receive messages, please bring your phone to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
I want to recycle my phone and accessories
Just drop of your old mobile phone and accessories at any Nokia Care point. Nokia will send the old products to closest Nokia approved recycling company. Mobile phone recycling leads to both material and energy recovery from old devices, and helps ensure the proper disposal of harmful substances.
Network for nokia 6310i
hi what happens when you put the sim card in is it new simcard and is the simcard registerd if its not registerd then you will have no network coverage as thie new simcard need registering
Mar 25, 2008 • Nokia 6310i
1helpful
5answers
No Signal, No Network, No Display
I think that the LCD is not aligned with the phone. Had the same problem when i open my phone.. Just realign the LCD and it would work..
Sep 18, 2007 • Nokia 6600
2answers
NOKIA 6310I
Trying to access the appropriate network manually. Check Reception or Transmission is working properly.
Apr 29, 2007 • Nokia 6310i
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
