Televison & Video Logo
Posted on Nov 06, 2009
The picture is shadowed it is worse when the picture is far on the screen
Lg 65ef9500 closed captions has burned screen
The pixels on the spot where the CC was are brunt out. The TV is not worth fixing. Cheaper to buy a new TV.
LCD Screen is showing degradation
One of my EDTVs has the same issue, though on a much smaller scale (it doesn't degrade the picture at all; it's only noticeable when the top of the screen is black, and it doesn't go down very far). Online reviews of the TV showed me it does have this problem commonly, so yours may too. It must be something you need to get it serviced for.
1helpful
Perfect sound , but no picture.
Hello
Just check whether there is any trace of picture [will be ver dark indeed]; can be seen on screen. Do a close watch and inform me. As far as sound is OK, there must be a dark shadow of picture on screen. I can post a solution to your tVs trouble only after get this information. OK.
2answers
TV has double picture. Ghost shadow is Blue.
looks like the t-con board failing, or a lose connection to the t-con or screen ribbons off the t-con board to the screen.
tcon-y0wguvybehhtyrwlmlutw4ro-5-0.jpg its fitted to the screen back under the shield will look similar to this.
Picture discoloration to left and right of screen.....
Hi! Guy,
This sounds like the G2 may not be properly adjusted, providing too much beam current.
This will some times cause feather edging, or lighter than normal raster on some scenes. This set should be serviced by a qualified service tech.
Toprol
Side shadows on picture
it sounds as if there are speakers to close to the tv or the built in speakers are not magnetically sheilded properly (maufacturer defect) if u have or have ever had speakers on the left and right side of your tv then the magnets in them will discolor and distort the screen. sometimes even long after the speakers have been moved away from the tv it will still look that way. you may try going to the library( or online )and looking in tv repair books on how to build a homade degauser unless your tv has that feature built into it in the menu somewhere like some computer monitors do. I had placed the front speaker of a 5.1 surround sound system on top my tv and it cuased that same problem, but i found out that by placing a small round magnet with a hole in the center on top of the tv (after removing the speaker for good) right where the discoloration was.. had to flip it one side or the other to get proper effect...it immediatly took away most of the discoloration and over time it disappeared. I hope this helps. Please email me at [email protected] as to your conclusion in case it will help others. thanks, Adam
Color shadows
PVAT!Check for evidence of coolant leak on pcb's, If none found,replace convergence IC's,then align convergence in servicer mode.Check service literature for procedure.
2helpful
Green shadows and curved picture
the convergence apms ic"s need to be replaced
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
