no signal found in my nokia 3100 mobile and there are no incoming and outgoing calls ,sms,etc,..no signal found in my nokia 3100 mobile and there are no incoming and outgoing calls ,sms,etc,..
AnonymousMar 05, 2008
clean contacts,reheat signal ic clean contacts,reheat signal ic
For past few days, I've no signal problem with my Nokia 3100. I tried my SIM in another phone and the signal was perfect, so it has to do with my mobile.
I saw your solution posted here, but would be great if you can send me the pictures of that as well.
Thanks
santoshHi,
Thanks santosh
AnonymousMar 31, 2014
Used to diplay time, network, signal, and batteryUsed to diplay time, network, signal, and battery
You can't post conmments that contain an email address.
Here is your solution. U need to open it with china screw-driver set. Then put a three fold paper under the two main ICs. CPU and UEM which both are looking same in PCB than tight the screws properly. This is caused by uncertain pressure on PCB. The PCB got bent and signal runs up quickly.
You must change PA(Power Amplifier) IC on your phone.5-6second signal than gone is a sign of PA IC not work any more.You know that PA is an IC where phone use to transmit.I hope it help.
First Option: Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So Secend Option: Your Phone Network IC Fault So Please change Network IC And Network Signal Problem will Solved if it is there isn't much you can do on this side of the network. Contact your phone company.
Thanks
santosh
