I have a Samsung CLX-3160FN that re-prints jobs all by itself. Everything that I printed during the day is re-printed when I come in the office in the morning. The jobs are cleared from the queue when I leave for the evening but the printer is somehow retaining the jobs in memory and reprinting everything somtime in the night. ??? Wierd
SOURCE: Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
SOURCE: Transfer belt error
Rather than turn printer off, unplug from power source, wait a few minutes and plug back in. It's worked twice for me so far...
SOURCE: CLX-3160FN Paper Jam when there
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
SOURCE: CLX-3160FN askes for replace TRansport belt, is it a
replace belt,take drum out slide transfer belt wich is located ontop of drum.see how it is connected,slides in/out.
SOURCE: How do I replace the tray 1 pick roller for my
Take out the tray, and you will find a pick rubber roller at the base.
Even you may clean and use it.
