Hi aburns983,
You can easily change the time and turn off the chime of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
SOURCE: Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
SOURCE: purchase watchbands for the timex 1440 sport
My son's watch (WR 50M) broke... so I have a strap, if you'd like it.
He loved this watch and it would cost about the price of a new one to repair, so I'm buying him a new one. He's had the same watch for years... bless, huh?
If you anywhere I can purchase another WR 50M - 1440 Timex, I'd be most grateful.
SOURCE: setting Timex 1440 sports watch
mcdevito75 here, For now, you need to know 2 buttons, the MODE and SET buttons, First press the MODE button, you may have to hold it in 2--3 seconds, see the display Blinking, now press the SET button for each function, (hour, minute etc). press MODE after each function is set, after all is set Press MODE for steady display. Here"s Timex Contact number for a manual, 800-448-4639
SOURCE: I have A Timex 1440
browse through my tips and you will find link for all Timex watch manual downloads.
