Hotpoint VBXR1090D Top Load Washer Logo
Posted on Jan 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clothes wet after spin cycle
My hotpoint washing machine will go inn spin cycle but clothes are soaking wet afterwards.had this fixed once before and I believe all he did was change a belt
  • Anonymous May 15, 2008
    wont
john mc donald
Level 2:
  • Expert 121 Answers
  • Posted on Mar 03, 2008
john mc donald
Expert
Level 2:
Answers
121
Questions
0
Helped
74689
Points
213
If its not the belt its your brushes in the motor that need replaced
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
2answers
Spin not working properly, sounds ok but clothes are too wet once complete and the independent spin cycle leaves clothes soaking!!!
Sounds like a small blockage in the outlet pipes, possibly just in the filter but check all outlet pipes. Just done one the other day and it was a clothes button that had passed out of the machine through the pump to the outlet pipe but had turned sideways inside the outlet pipe.
4helpful
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
CLOTHES NOT SPINNING DRY
you have something stuck in the pump..a sock maybe or some other small article of clothing
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
With my hotpoint washing machine the clothes are soaking wet at the end of the cycle, don't know if its not spinning properly or what?
hotpoint machines are renowned for needing carbon brushes to be replaced in the motor they usually last between 12 months to 2 years depending on the amount of use the machine has.i would check these first as they are a common cause of hotpoints not spinning, if they are ok then check the pump and sump hoses for blockages (not emptying water out)
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
