I have a sony 51" rear projection TV. It is supposed to be HD capable (1080i) using the Video 5 input only. When the cable installers attempted to acquire a 1080i HD signal on input 5, the entire screen turned green.
The connection from the cable box to the tv was through component cables.
The cable installers programmed and reprogrammed the cable box to make certain that the correct signal was being generated. Same result--green picture.
The cable installers opined that there might be a problem with one of the video ports. If so, is this a major problem or expense to fix, or are there other possible fixes I can try?
Thanks.
AMK
SOURCE: Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
