HP Officejet 5610 All-In-One InkJet Printer Logo
Posted on Nov 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The error message says "cycle power try scanning again". What should I do?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Nov 05, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557224
Points
31058
To "cycle power" means to first turn the printer off, and then to turn the printer on.
To "try scanning again" should be self-explanatory.
"cycle error" - scanner powers up ok but will not scan due to this error ID=055
Error 55: "Lamp I2C error reading from DAC". Operator log message: "Cycle power, if problem persists, call service.". This error is involves communication errors between the LED AY and the DAC. A couple things can be done to alleviate this issue but unfortunately, as a user, you can only perform the first step. The other steps require a Kodak Field Engineer to complete. First step, upgrade your Firmware. Firmware updates can be found at the following web page: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Production/i5200_Scanner/Support/Drivers_And_Downloads/i5000_Series_Scanner_Firmware/index.htm. If you still experience issues following the firmware upgrade, call Kodak Service & Support to schedule a field engineer to be dispatched to your site.
2answers
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Turn off error 000FBB6
Hi, Try this, Unplug the unit for 30 min. and then try it again. all connections. This should set the machine to default.
3helpful
Samsung CLP-315 color laser printer Haven't used it for a couple months. Tried last night, got "system error" message. It said to cycle power. Tried that 5 times alst night, no joy. Left...
When you cycled the power, did you just push the power button?
If so, to really do a power cycle you need to unplug, let sit off for 30 seconds, then plug back in.
1helpful
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
1helpful
2answers
Getting a message
Have this checked with another scan tool. Link error is produced when the PCM fails to respond to the scan tool. More times than not this is the PCM failing.
2answers
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
1helpful
Fax and cancel lights are flashing
I found this solution at HP website. It worked for me. Good luck!
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner’s inability to find the home reference point.
SOLUTION:
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to “walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle.
k24674
Grand Canyon Tech
Grand Canyon Tech
