Roper RAX4232KQ Top Load Washer Logo
Posted on Nov 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I removethe lint? Clothes are coming out with fluff...
  • Marvin
    Marvin May 11, 2010
    are u serious u really don't know why this is happening??
  • Anonymous Apr 19, 2012
    Dennis, its obvious that you didnt know that he's asking about a washer and not a dryer. Read questions carefully before you deem someone as stupid.
Jim DuBreck
Level 3:
  • Master 578 Answers
  • Posted on Nov 05, 2009
Jim DuBreck
Master
Level 3:
Answers
578
Questions
Helped
252681
Points
1695
Sorry for the obvious.....
Fluff on the cloths is from the lint trap not capturing it from the air flow.
Air is passed into the clothes from the laundry room. It is heated and then passed over the clothes... then filtered air is forwarded to the outside exhaust.
If you are seeing lint on your clothes, then the air coming in from your laundry area is not lint free.
1. check the back/bottom of the dryer for lint accumulation.
2. Remove the lint trap and clean out the duct work.
3. Inspect all the flooring and areas around the dryer for dust/lint - and clean any that you find.
I believe that you will then have a clean and dry load.
The proceedure of cleaning described above should be repeated every 6 months or so....
-Jim
  • Jim DuBreck
    Jim DuBreck Nov 05, 2009
    -Jim
  • Jim DuBreck
    -Jim
Is there a lint filter i am getting white fluff on black and dark coloured items
if it is a top loader ( type and make not mentioned ) the lint filter is at the bottom of the center section of the tub spindle
just pull that section up and the filter is at the bottom
check for paper left in pockets ( tissues, dockets etc) as paper appears as white fluff on clothes
2answers
Fluff on clothes
Some washing machines have a filter usually bottom right hand corner, you can clean this out.
They do say every once in a while to run the machine empty on a boil wash and add a little bleach or try some of these commercialised cleaners that remove limescale etc it cant do any harm.
Do this once or twice if its still bad the only thing i would suggest is to get a new one.
Why maytag washer is leaving white streaks on my dark clothes
It's lint that hasn't lifted off of the garment. Fluff it in the dryer to remove and find in lint filter when done.
Where is the filter on speed queen
Please check this link for information about cleaning the link filter and identifying. How to empty the washing machine lint filter
Speedqueen does not wash clean. Always white fluff on clothes. Is there a filter to clean
Clean you 'lint filter' - see your instruction booklet or if you don't have it google your washing machine model and see where the lint filter is and how to clean it. It's usually a small pouch on top on the steel drum that you have to slide out and clean.
Hope this helps.
I have a whirlpool top load washing machine model no. 6ALSQ8000JQ2. it is about 7 years old and does not have an area that collects the lint in the machine. Previously this was not a problem, but in the...
You have taken the necessary steps to reduce the lint problem. It seems they have not worked sufficiently. Another lint factor is due to HARD WATER.
You may have to disassemble the washer and remove the inner wash tub. On the bottom of the wash tub is a self cleaning lint filter. It may be gummed up with detergent and lint not allowing it to do its job. It will have to be manually cleaned.
My dryer makes my clothes stink
You NEED to have a professional vent company clean your dryer out! PLEASE don't run your dryer when you're alseep or not at home due to a fire hazard! It sounds like the dryer is full of lint that's buring and make sure you clean your lint filter EVERY time you dry a load for safety's sake and energy efficiency.
Aug 14, 2009 • Dryers
Fluff on left on clothes
the lint filter is your problem needs to be cleaned out, the agitator which is the thing in th middle of the machine houses the lint filter the top should just pull off
2helpful
2answers
Fluff left on clothing
Maytag Performa Washing Machine!!
All our clothes are being ruined with continuos fluff sticking to items.Have tried hot wash -no clothes, same problem.
Have tried not using Fabric Softener still no solution.
guest
Top Roper Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
