1. Connect your MP3 player to your computer using the supplied USB cable. The cable hooks into the bottom of the player.
2. Open Windows Media Player on your computer. If your MP3 player is connected properly, the media player will display The Name Of Your Player in its menu. This is where you place your video files.
3. Locate the video file you want to put on your MP3 player and select it by clicking on it with your computer's mouse.
4. Once the video is selected, "drag" the video across the media player to your mp3 players name display on the player.
5. When your player's name display lights up, release the mouse to "drop" the video into your MP3 player's video file.
6. Repeat the process to place additional videos.
SOURCE: it wont let me put videos on my mp3
If you go to windows media player put your video in there then rip them into your player the same way as you put music in
SOURCE: I cant put videos on my mp3
try to use this video converter to convert to amv file , have work on my mp4.
http://downloads.open4group.com/download/programas/mp3-player-utilities--40-5622.html
youtube video donloader
http://www.ziggi.com.br/downloads/ashampoo-clipfinder
SOURCE: how do I put videos on my Philips Mp3 player?
You have to use the Philips (Arcsoft) Media Converter to convert/transfer videos. If the converter is not recognizing a specific video type - FLV, for instance - download a free program called Riva FLV Encoder and convert the videos to AVI format first. Then the Philips Media Converter will recognize them.
The Philips Media Converter is not capable of converting an entire DVD - you will have to acquire video editing software, and then break up the DVD files into 15-minute chunks, and then convert each chunk.
If you are getting a codec error, do a google search for free video codecs - they are out there. Windows Codec Pack and downloading the latest version of quicktime will give you most of these needed codecs.
This player is not capable of playing copyright-protected videos - so don't even bother with them.
Additional information is available both from Philips website and from Arcsoft's website.
-Tha Mp3 Doctor
SOURCE: cant put videos on mp3
It may be that your mp3 has specific file formats that it accepts for videos, which is most common - in which case you will have to covert or compress any standard format video into an acceptable video.
Your vidoes may be too big in actual screen size or your slick mp3 player doesn't accept videos.
You may also need the software compatible with your mp3 player in order to download video's successfully. You will need to download or install the software for your mp3 player which will make it easier to upload vdieo's. You may be able to do this via the manufacturers site, or prompted to do this when adding the device to your computer.
SOURCE: DONT UNDERSTAND HOW TO PUT VIDEOS ON MP3 PLAYER
I agree with fake192, you will need to convert your videos for them to play on your player.
If you don't have the AMV Converter, you can also download it from either http://mympxplayer.org or http://mympx.org.
Hope that helps.
