Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher Logo
Posted on Nov 04, 2009
I have a bc20 slim integrated dishwasher that won't drain.......
I have a bc20 that has recently started to make a humming sound whilst running has always been quiet before, also water is left in the drain point at the bottome of the washer after a wash and also seem to be dirtying my dishes rather than cleaning them is this a fault with the drain pump or could it be a motor fault due to the noise?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 03, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
542
Points
Mine too, did you ever get it fixed?
jerawlings at aol.com
2answers
My samsung dishwasher has a constant buzz that occurs during start up and lasts through all of the cycles. I saw where there is an electrical noise filter and did not know if that could be the cause.
No a noise filter is a different kettle of fish. That stops electrical interference noise from affecting your television, radios and electrical devices.
The most likely source of the hum is the start capacitor on the motor, or the motor itself.
https://www.google.com/search?q=samsung+dishwasher+start+capacitor
This has a different idea
Humming or Grinding If your Samsung dishwasher makes noise when starting that sounds like a low hum, it's part of normal function. The motor makes this sound as it operates throughout the wash cycle. However, a dishwasher making loud humming noise or grinding sounds could mean that debris is caught in the drain pump.
Samsung Dishwasher Making Noise? Follow These Tips
This says the drain pump, but the drain pump only runs to empty out so it wouldn't do it all the time.
https://kitchenbuds.com/dishwasher-guides/samsung-dishwasher-making-grinding-noise/
Lots of other ideas and videos
https://www.google.com/search?q=samsung+dishwasher+humming
1helpful
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 • Dishwashers
F&P dishwasher DW60CDX1 (5yrs old) which will drain then fill but will not start the wash cycle. No error codes just a humming sound, possibly faint electrical burning smell (turned off quickly in
We just had this problem, the dishwasher filling, then humming with a slight burning smell. It would drain ok if turned off then on again. It was the capacitor. The part cost $27 and the repairer charged $73 to fit it.
1helpful
Loud humming just started during wash cycle
Humming can be simply due to a mechanical vibration when the wash pump is running. Alternatively it could be the sound of the detergent door solenoid which might be stuck.
Will need make and model number of dishwasher to give further advise. Does the dishwasher complete the cycle and drain out the water?
Feb 13, 2011 • Dishwashers
4helpful
GU1500XTL loud humming sound during the cycle, getting louder
The run capacitor on the main wash motor needs replacing. Eventually it will just hum and overheat instead of rotating, so better replace it now before it overheats.
I doubt you can acces it easily yourself, as it may be away from the motor, and have to be tracked down.
LG LDF6920ST Dishwasher won't start
With nothing displaying and only the humming sound, it appears that the main controller card (PCB) has most likely failed.
If it were my dishwasher, I would add a pitcher of water (more than two big glasses full), close the door and start a cycle and listen at the drain. The first thing a dishwasher does is run the pump to empty any standing water before it fills up. If you hear that water drain, (and can see that is has drained from inside the dishwasher) it is not as broken as I think it is.
BUT, this dishwasher should be displaying something from the moment you press the power button.
Please post back with what you find and decide you do. OK?
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
BEEBING CONSTANTLY ADG7460 WHIRLPOOL NOT DRAINING
This dishwasher being only seven weeks old I suggest you contact the store where you bought this unit and tell them to book a service call and send a technition out to solve this,the reason I am suggesting this is that the unit is under guarentee and if you try to repair it will void any guarentee or warrentee that is on the machine.If you do work on it and something big and expensive goes wrong the store(manufacturer) will not honor there guarentee when they see that you worked on it so better to be safe than sorry.If you do not come right with them let me know and we can see what we can do from there.
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
