Hello
Absence of green is the problem. You see mixing of red and blue, which will look like pink.
the fault must be of its video output card. This card can be located at the neck of the picture tube. Check this card, for any loose solder. This is a common problem seen in most CRt based Sony TVs.
Just resolder all the suspected solder points on this board, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals.
images of two models of sony trinitorn TVs, [back cover opend] has been attached here. you can see the boar under suspection, along with the picture tube neck. [See the rectangulat printed circuit board attached to CRT base]
Screen is black even though the sound comes through. TV is hooked to a receiver and DVD. Tried to play a DVD and still sound but no TV picture.
No picture just sound and a pink screen. Menus still come up on but screen remains pink
