Technics SL-1200 Turntable Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY Technics 1200 Rotates Out Of Control. What needs To Be Done To Fix?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
308
Points
Your pitch control is worn out,buy a new one and replace it
David Shaub
Level 3:
President:
  • Master 2,994 Answers
  • Posted on Nov 04, 2009
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1152532
Points
8370
It sounds like you need to replace the belt. If it's too loose, it will not maintain the proper speed.
How to calibrate control on a technic 1200 by sight
Put the pitch slider to +6 and adjust the internal preset until the top set of dots on the platter are stationary.
Check again with the pitch at +3.3 if the dots are stationary then job done!, if not then the pitch slider is worn and perfect calibration won't be possible until the pitch slider is replaced.
http://stores.ebay.co.uk/methleykev
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from [email protected]
When using my pitch controll the spped does not
the pitch control slide potentiometer needs to be replaced. This is a common failure on the sl-1200 series.
Pitch Control Problems
More than likely the pitch needs to be calibrated. Although not very hard, I would suggest getting this done by a professional, as it does require opening up your turntable.
Here are instructions - TECHNICS PITCH CALIBRATION
If you cannot perform this, then find yourself a good technician who knows what they are doing.
If this does not work, more than likely either your pitch control, the pitch gain, or one of the IC's need to be replaced - at this stage, only a qualified service tech can help you.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
My 1200 was sitting on the carpet for a week in arizona and now does not turn on?
Check the fuse underneath the platter. You'll have to remove the protective cover to access this area. If your unit has fuses (not all do), it will be on the lower left side. If you do not see anything, then your unit does not have any fuses, and this means that the power transformer (the big grey metal box thing) is damaged and needs to be replaced. I only suggest this be done by a professional service center.
- OPTiC
MasterTech
Technics Parts : Technics DJ Repairs
Help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Speed control issue
Not sure I understand what you need done. The 1200 has a pitch control, which allows you to control it's speed. Do you want to disable the 33/45rpm function, and assign that to the pitch control, so instead of controlling pitch, you control the RPM? This will put quite a strain on the drive circuits of this unit, but it can be done. Although, not an easy modification, as you will have to modify multiple resistors and IC's on the main board. This should only be professionally done.
- OPTiC
Technics Repair Videos
Technics DJ Repair
DJ Equipment Sales
Technics Parts
Pitch Slider
You more than likely have to have the pitch control replaced or cleaned.
- OPTiC
Technics DJ Repair
DJ Equipment Sales
Technics Parts
1helpful
Technics 1200sl pitch control
There seems to be 2 issues with this unit. Usually when the platter speeds up very quickly, one of the IC (integrated circuits) are faulty and needs to be replaced. However, I've never seen the 33/45 lights come on in addition. So, perhaps the issue started with faulty 33/45 switches, and it then caused a short to one of the IC's.
This will have to be professionally serviced, as it is not an easy fix. There are various circuits on the main board which control the drive, so it's a matter of diagnosing which is the culprit. The 33/45 switches will also need to be tested/replaced.
- TERMiNAL OPTiC
www.DJPROLAB.com
Technics SL1200 MK II Speed problem
this one happend to me!! try taking the plastic cover off, under the platter and removing the screws that hold it on if that cures it its because what you ll find is that the screws just catch the underneath of the platter as it rotates. happy mixing
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
