Hello
If there is a driver file in the Zip file you downloaded, just manually install the driver. Go to device manager, the flash drive should have a exclamation mark next to it. Then right click on it and go to properties. Update driver software and select the driver file in the zip file. If this does not work, i would suggest that you set up a network via Ethernet cable between the 2 machines.
Best regards
Andrea
It should be unzipped and path to the unzipped folder provided while installing new hardware, when Windows (after plugging in the stick) finds a new plug&play device and asks for the location of drivers.
Also, go to your newer computer and check the USB stick's drive properties - it should be formatted using the FAT or FAT32 file system. If it's formatted using NTFS, Windows 98SE will not see it.
