My sony xplode 1000 watt amp just went out it was working then it just stoped ??? i dont know what happened but the protector light comes on green then turns red its hooked up to my fusion 12" sub and ive tryed with a 8" buzka tube and checked all my fuses but nothings wrong its been briged and i cant find a reason for it to do this should i cut all power and hook it back up ???
Just to the left of the output (speaker) terminals, near the top of the amp, there's an LED marked "POWER/PROTECTOR". If the amp is connected properly and powered on, the LED is ON.
If the amp is being used for normal speakers, use a pair of RCA cables and connect the left/right channels to the appropriate inputs on the amp. The switch marked "LPF" should be "OFF".
If the amp is being used with the channels bridged for a subwoofer, use an RCA "Y" adapter and connect the single "Sub Out" preamp output from the head unit to both amp inputs. The switch marked "LPF" should be "ON" and the crossover set to about 80-100Hz.
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Sounds like the power supply is shutting down because of it sensing a bad output channel. I'm assuming of course that you have checked all your battery, ground, and trigger wires to see if they are OK. Good luck.
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
Almost all after market amps use 12v at very very low amperage to trigger the amp on. A temporary jumper from the battery plus terminal on the amp AFTER the battery and ground wires are attached should cause the amp to turn on. I would check to see if you have attached your speaker load correctly ESPECIALLY if you are bridging. Most of the blown amps that come into my shop are due to incorrect bridging loads from the speakers. Note that a 4ohm load bridged across both outputs of an amp will deliver a 2ohm load to each of the channels. When you parallel wire two 4ohm speakers together and then attached them to a bridged amp you will be putting a 1 (one) ohm load to each channel of the amp. Please don't make this mistake. It will fry your amp in about a month. Hope this helps. Good luck.
