Posted on Jan 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sing along cd wont play
I have a sing along cd player for my child, cant get cd to play?
Anonymous
Level 2:
Scholar:
  • Expert 103 Answers
  • Posted on Jan 08, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
103
Questions
0
Helped
37979
Points
248
These are funny little things.
Sometimes the door fails, so make sure it's fully & properly closed. It will not play CD-RWs (rewritable discs) & might not play CD-Rs either so make sure:
1. The batteries are fresh (high power alkaline), or better still, you are connected to the mains.
2. You are using a pre-recorded (shop bought CD)
3. Your unit isn't being moved or rocked. Although this looks like a "portable unit" it does not have any anti-shock or bufferring so moving the device around while trying to play a CD won't give great results.
Let me know how you get on.
1helpful
Why would my AM/FM radio work only intermittently while the Satellite radio & CD player work normally?
Simple stuff really. Your antenna picks up analogue radio waves for ordinary radio (weaker signals drop out). Satellite signals come from above (way more reliable "direction" no obstacles and different bandwidth. CD player is different because it has it's data there already. So.............play a CD if your radio drops out. If your CD breaks along with the radio......sing ! I do it all the time (damn sight better than some rubbish on radio).... x
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
1helpful
CD tray wont stay closed
Try using a CD cleaner. Generally this sort of problem occurs due to dust accumulating on the lens. The CD cleaner comes along with a solution.just spray on the CD and allow it to play in the CD drive. Sometimes the problem might even be due to a virus. Check whether your anti-virus is up to date.
Singing machine SMG 301 problem
has a bad drive motor, not sure where you can get parts for these
Display keeps saying door
When your site kicked me out and charged me twice, I through the singing machine away! that solved the problem.
2answers
When I play cd's the music jumps
Make sure the speakers aren't too close to the CD player. The sound waves could be causing it to jiggle around like Elvis singing Blue Suede Shoes.
 Grubhead
Grubhead
SmartAviator
SmartAviator
