HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
If there is a power cut to the property, or the power to the oven is turned off, the oven may display a "STOP" error message. If this happens, the oven will need to be reset and the time set before the oven can be used. To reset the oven, follow the instructions below: Ensure that the 2 outer knobs are fully pushed in. Press the middle button and keep it pressed in until told to release it. Push the Left button to release it. Now turn the Left button one complete turn clockwise (the oven should beep) and push the left button back in. Now release the middle button. Push the right button to release it. Press the middle button twice. Now turn the right button to set the time. When the time is set correctly, press the middle button to save the time. The oven should now be reset.
