I have a flybook vm and the webcam is not working.. i tried instaling drivers .. but could only find the win xp ones .. i'm usin win seven, and the update doesnt help.
Select your webcam model and download it (Camera/Webcam) driver or you can Try installing the latest webcam driver. Download the device drivers from the Acer WEB site. Makesure you select
the model of your laptop the drivers you that require thatmatches the
Windows version that is installed on your laptop. Use this link toget to
the Acer support site :
The VM is a very hard machine to work on. You have to start by taking off the battery. Then remove all the screws on the bottom of the case chassis. Once that is done, with the screen extended, carefully run a soft wood chisel or a fingernail around the machine, releasing the clamps on the side of the system holding the plastics together.
Once that is done, you will carefully have to pull away the bottom case from the rest of the system. That will expose your HD and memory.
first look on your cam for the model number and brand
example veo stingray 4420 drivers is what you would type in search, next go to the websight for drivers or firmware firmware is same as the cd program, this is a bigger download, under support webcam web pages
to install drivers, start settings control panel classic view should be on, then system on bottom hardware tab device manager, look for yellow mark next to cam, right click properties,update drivers then find cd location on hard drive or have microsoft update search for it automatic
It seems that you will need to contact the manf. directly for this. I am assuming it is not just a matter of opening a door to upgrade the RAM, most likely have to take the entire thing apart.
"Hello, just letting everyone know, if the system is disassembled
outside of the service center, your warranty can no longer be covered.
If anyone needs a service upgrade or RAM upgrade, just contact Flybook techncal support. Email is: [email protected]"
