Singer 2732 Mechanical Sewing Machine Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot get my sewing machine stitch the different stitches. I've followed all the instructions in the manual and all I get are straight stitches. I want to get a zig zag. Sometimes it looks like it did it but it is too small to do any good. I've tried all the largest setting I could to spread it out but it still comes out straight in the end.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3083
Points
Widen the the stitch width "width is side to side" stitch length is forward and back, widen the width and watch the needle go side to side.
ken dourof
Level 3:
  • Master 980 Answers
  • Posted on Nov 04, 2009
ken dourof
Master
Level 3:
Answers
980
Questions
0
Helped
264261
Points
1919
When you select a pattern does the needle move back and forth? do you make sure the stitch width lever is on straight stitch then select your pattern then select the widest stitch width? if when you select a zig zag stitch the needle does not move from side to side then you need to look in the top at the finger that goes round the cam.
  • Krisel Andersen
    Krisel Andersen Mar 29, 2015
    Do I need a cam for zig zag? I don't remember my other machine needing one. If so which one for 600e?
  • Krisel Andersen
    I got the needle to go back to the center and it does move to the left when I adjust from 3 to 5 in width, just doesn't go back/forth.
1helpful
I have a Bernina 930 record, zigzag stitch it misses some zigzag stitches & does straight stitches
If your Bernina 930 record sewing machine is experiencing issues with zigzag stitches and straight stitches, here are some troubleshooting steps you can try:
  1. Check the needle: Ensure that the needle is properly inserted and not bent or dull. Replace the needle if necessary, making sure to use the correct needle type and size for the fabric you are sewing.
  2. Adjust the stitch width and length: Verify that the stitch width and length settings are properly adjusted for the desired zigzag stitch. Refer to your machine's user manual for instructions on how to adjust these settings correctly.
  3. Clean and lubricate the machine: A build-up of lint or lack of lubrication can affect the machine's performance. Clean the bobbin area and other accessible parts of the machine using a soft brush or lint brush. Apply a drop of sewing machine oil to the recommended areas as specified in the user manual.
  4. Check the tension: Improper tension can lead to skipped stitches. Ensure that the upper thread tension is properly adjusted for the fabric and thread you are using. Consult the user manual for guidance on adjusting the tension correctly.
  5. Test with different fabrics and threads: Try sewing on different fabrics using different types of thread to determine if the issue is specific to certain materials. This will help identify whether the problem lies with the machine or the materials being used.
  6. Have the machine serviced: If the above steps do not resolve the issue, it may be necessary to have your Bernina 930 record serviced by a professional. There could be underlying mechanical issues that require expert attention.
It's important to note that the Bernina 930 record is a vintage sewing machine, and finding a qualified technician with experience working on older models may be beneficial if further repairs or adjustments are needed.
I need a manual for a dial and sew 750 sewing machine
Unfortunately, I couldn't find a specific manual for the Dial and Sew 750 sewing machine. However, I can give you some general instructions on how to use a sewing machine that may help you get started:
  1. Threading the machine: Follow the threading guide and thread the machine correctly. Make sure that the presser foot is raised when threading the machine so that the thread can be properly tensioned.
  2. Winding the bobbin: Place the thread spool on the spool pin and wind the thread onto the bobbin by following the instructions in your manual. Make sure to cut the thread once it's wound.
  3. Installing the bobbin: Open the bobbin case and place the bobbin inside it, making sure the thread is coming off the bobbin in the correct direction. Then, pull the thread through the slit in the bobbin case and hold onto it.
  4. Adjusting the stitch length and width: Depending on the fabric you're working with, you may need to adjust the stitch length and width. The stitch length controls how far apart each stitch is, while the stitch width controls the width of the stitch. The controls for adjusting these settings will be on your machine, typically on the front or side of the machine.
  5. Sewing a straight stitch: Practice sewing a straight stitch by lining up the fabric with the edge of the presser foot and slowly pressing the foot pedal. Keep your hands on the fabric, guiding it through the machine. Be sure to sew at a consistent speed to maintain even stitches.
  6. Using additional stitches: Many machines have a variety of stitches you can choose from. Consult your manual to learn how to select different stitches and adjust the length and width settings.
  7. Finishing your sewing: Once you've finished sewing, cut the threads and remove the fabric from the machine. You may also need to clean the machine and oil it, depending on the manufacturer's recommendations.
Remember to always consult your manual for specific instructions on how to use your particular machine. Good luck with your new sewing machine!
Straight stitching on singer model 1525
Do you have a setting for design stitches? There should be a button to take the machine to a straight stitch. Look at your manual or instructions to see how to set it to straight stitching. If this doesn't work, look up on the website on your machine and see what the company thinks about it. Sometimes the mechanism is malfunctioning and the will send you a new machine.
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
My Kenmore Mini Ultra sewing machine won't sew the button stitch. I have followed the instructions on the manual but still the thread does not get sewn onto the fabric. Simple straight stitches are ok
it's possible that there could be a problem with the gear or cam that does the button hole stitch
try a different needle--one for the fabric being sewed
try a different bobbin --make sure the bobbin is not warped or damaged
try different thread-- use EVERY thread guide
make sure the bobbin is wound correctly--inserted correctly in to the bobbin case--and turned the right way.
1helpful
2answers
How do i set the needle position to the left. I want to set it to tie of the thread after sewing on a button using Stitch No. 73.
It appears on page 27 of the manual that there is a way to manually set the needle to 13 different positions using the stitch width control. You might need to set it to straight stitch function first.
Babylock denim pro
I'm not sure what you've actually got, since your question mentions two different machines. Straight stitch is typically the default setting (the thing that comes up automatically) on computerized or electronic machines. On other machines, there may be an indicator for straight stitch (often stitch 0 or 1 if numbered), or it may be a zigzag stitch of width 0, length whatever.
3helpful
White XL1760 cant find the setting for the straight stitch.....a, b, c????
You can download a manual for your White machine from the Singer website, link is
http://www.singerco.com/uploads/download/1111_white-1760-xl-x.pdf
Here are the relevant pages from the manual:
Straight stitch settings as follows:
stitch length on 2.5 (selector marked with blue arrow)
stitch width on zero (no swinging of the needle) selector marked with red arrow
stitch selector on A - selector marked with green arrow
Generally all sewing machines will have a similar three controls, because all stitches are a combination of moving the fabric forward a certain amount between the needle going through the fabric - the stitch length; and moving the needle from side to side - the stitch width.
And then a stitch selector for different stitch forms such as a blind hem or shell stitch where the needle is going through a series of different moves in sequence to form a special stitch. You still have the width and length controls to vary this formation.
For general sewing machine information www.sewing.about.com is excellent, there is lots of pages on general tips, cleaning, threading up and sewing machine know how. Try this page to start http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machines.--9k/
If you are a beginner, then I'd recommend printing out the instruction manual for your machine and putting into a binder, placing beside the machine, and carefully read from the beginning going through all the instructions to wind a bobbin, thread up, three or four times until you can do it without reading the manual, then practice stitching out each of the stitches your machine does. Buy a cheap exercise book and on each page, write the name of the stitch, staple the stitch sample in and either write down the settings used or glue in a photo taken of the machine controls you used. This way you can quickly flick through and refer to your settings next time. ADjusting the top tension dial will also adjust the stitch formation so read the manual and set the tension dial to the setting it suggests but sometimes you'll need to adjust it slightly to get the stitch looking even (balanced between top and bottom thread), especially for zigzags.
Practice a bit and you'll soon feel much more confident using the machine. Also, refer to the cleaning and oiling instructions and do it regularly, along with changing the needle for each new sewing project, about 4-6 hours sewing time. The needle is the most important part of a sewing machine, always use the right sized needle for the fabric. Refer here for info http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
I hope this helps you with your White sewing machine, there are lots of great sewing machine books on the market too or in your public library to refer to. Also taking beginner sewing classes will really help you learn how best to use your machine. I've been sewing for over 38 years but still enjoy going to a class and learning a new technique from another enthusiast - life long learner!!
I have a Kenmore sewing machine Model 158.17030. It's an older model and I don't have the user manual. I can't figure out how to set it on the hemming stitch. No matter what I do, it just sews a straight...
Hi. First, I'd recommend you get a replacement manual. They are really useful. Check out http://sewingpartsonline.com/sewing-machine-instruction-manuals.aspx.
I assume you have different stitches on the machine and a diagram of some sort showing what each stitch looks like. Find one that looks like:
---^---^---^--- (maybe on its side). That's the blindstitch. Some machines require you use a blindstitch foot with the stitch, but some don't. Without the user's manual, it's hard to say what your machine requires.
Good luck and let me know what happens.
Robbie
4helpful
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
