Dewalt 1/4" Sheet Palm Sander  Logo
Anonymous Posted on Nov 04, 2009
How to remove the stick on paper?? dewalt 1/4 sheet sander
  • Anonymous Nov 04, 2009
    paper stuck on real good
    foam is coming up off base
Anonymous
Level 2:
Sergeant:
  • Expert 302 Answers
  • Posted on Nov 04, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
302
Questions
0
Helped
116112
Points
740
Grab a corner of the paper and peel it off
Testimonial: "thanx"
    warm it up with a heat gun or hair dryer and this will loosen the adhesive up. Hope this helps you
2answers
Palm sander
The answer "Go to Dewaltservicenet" can be confusing - the actual site is servicenet.dewalt.com and even then, entering your part to get to manual can be infuriating. This is the link for the current model which, for all intents and purposes, is the same. The link to the helpful page is: http://www.dewalt.com/tools/woodworking-sanders-orbital-sanders-d26441k.aspx . You'll get a pop-up box with a dropdown that has a few numbers, nothing else. Just click on "1" and ignore language that indicates that this model has more than one - it does not. After you click on "1", the pop-up disappears that you're on the d/l page. Downloads are in the upper right corner. You want "Instruction Manual".You should get to this page: http://servicenet.dewalt.com/Parts/Browse#6229 but may not, it's very glitchy. On this page, you'll want to make sure "Sanders" is on the left and "sheet" is on the right. If you try to get the Manual from the DW411 page, a blank page will open. Make sure your pop-up blocker is off or that you allow dewalt.com. The instructions for the d26441k are identical to the dw411 - same technique for loading sanding sheets, same rods, etc. I've uploaded the d26441k page manual .pdf so that should help. It's easy to get lost on the Dewalt site while trying to find somthing so simple. :)
Where to apply grease
There are no parts in your sander to grease. The only place there is grease is in the three sealed bearings on the armature and in the platen. Everything should be clean and dry inside the sander to make it less likely for sawdust to stick inside the tool. Blow everything out and replace the bearings if they are not turning freely and smoothly.
When I bought my sander it has what i would describe as a rubber pad onj the sander. Is this the sanding pad?
That sounds right. It is probably the type that uses adhesive backed paper. You stick the paper to the rubber pad.
1helpful
Can't figure out how to load the sand paper on to the mouse sander
Just stick the sand paper sheet to the base of the mouse sander... it's velcro it will hold... match the forme of the paper with the forme of the sander's base... that's all...
Cheers!
DW411 Can I put a velcro pad on this sander so I don't have to fumble around trying to get sand paper on it
Dewalt is not going to make an accessory for you to do so, since that sander was designed to use 1/4 sheet sandpaper, and therefore takes standard paper clamped in place. You could make your own base for the sander out of thin plywood or some other suitable material, covered perhaps with a laminate or rubber surface, that would accept PSA (pressure sensitive adhesive) sandpaper, which you can buy in rolls appropriately sized for your sander. Or you can try some kind of after-market conversion kit such as this one (See also here, etc.)
If you really want a hook and loop base on your sander, I recommend you bite the bullet and simply purchase a random orbital sander with a H&L pad. Then you'll of course have to buy the perforated paper discs to go with it....
But you'll easily be able to change grits, and the performance and quality of your sanding will improve.
You might check the reviews in various woodworking magazines before you make a purchase, just so you know what you're likely to get for your money. There's a vast array of machines made, and the quality varies accordingly, and depends to some extent on your budget and intended use.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Air and dust no longer blow into dust collection bag. I suspect that there is a clog somewhere.
are you putting holes in the papper with the guide? there has to be holes in the paper for the dust collection to work
5helpful
Where can I get instsructions for the Dewalt DW411 Palm grip sander and also what type of sand paper do I get to fit it.
go to Dewaltservicenet.com and in the midle of the page and towards the bottom under need manual type in your model number and you should be able to download anbreakdown and operators manual
No sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
Top Dewalt Tools & Hardware - Others Experts
john h
Sean Wright
Sean Wright
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
