More than likely you have a bad ignition switch, it sits right behind the selector knob, and has two wires
when you twist it, you basiclly complete a circuit,, sounds like the switch for that burner went bad,,,,
depending on your model it is a reletivley easy fix...
the parts should not run you more than 10.oo
and not take you more than a 1/2 hour
depending on your instalation
goto
www.appliancepartspros.com
type in your model number
it is called an ignitior switch or ignition switch
this site is very good it will also goive you a visual breakdown of how to get to the part
you should be able to take the top right off and gain access to the switch
This model # SGM466S does not come up on parts search
Thank you , for all your help!
