Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have removed the thermal sensor(radiant sensor) in my kenmore 80 series and i don't know how to put it back theres only two wires one green and one white but i forgat wich one goes on each terminal.
Anonymous
Level 3:
President:
  • Master 1,304 Answers
  • Posted on Nov 03, 2009
Anonymous
Master
Level 3:
President:
Answers
1304
Questions
0
Helped
367481
Points
3700
It does not matter witch way it goes on it is really just a thermal switch open or close
there is not a polarity difference or circuit monitor
mount it wire it and forget it
I have an 80 series kenmore gas dryer, will not heat, is it the starter? where can i get one, is it an easy fix? don
it could be the glowbar that ignites the gas,or it could be the thermal fuse in the dryer vent housing,the radiant sensor on the burner tube box that detects the flame and keeps the gas valve open,or the gas valve boost and secondary coils on the gas valve are open or weak and can't keep the valve open any longer,you need to remove the front cover and top cover to remove the drum to check any or all of these components
3helpful
2answers
80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Kenmore 90 Series Gas Dryer No Heat. Have replaced both Coil Valves, and thermal fuse. Gas ignites, runs for 15 seconds then turns off. All ducting is clean. I bypassed thermostate same problem. I also...
try taking off the vent line and run it,also did you remove and clean out the duct that the lint filter slides into,send model number,sounds like a venting problem or a thermostat problem,take out the thermostat and see if there's any lint or junk stuck on it
Dryer won't run.kenmore 80 series
If you have voltage go to the door switch 1st. Make sure there is a clicking when you push the switch manually. If there is remove back panel and you will see a white plastic connetion with 2 wires, this is a safety thermal,(fuse). If you don't have a meter then jump these 2 wires together making sure not touch the cabinet then plug unit in and see if it will start.
Replaced igniter and thermal fuse and still no glow from igniter and no heat
could be that you have a bad radiant sensor. or timer? unplug the unit and check continuity across the radiant sensor, you should have continuity. the radiant sensor is attached to the left side of the flame tube. make sure you remove one of the terminals first from it to get a more accurate reading. if that is good you should have one more fuse inside of there it is usually small and round with 2 wires going to it and it is also usually attached to the flame tube. you should have continuity if not this would be your problem. let me know if you have any other questions.
No heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
1helpful
Kenmore 80 series gas dryer not heating
THE SOLENOID IS A REPLACEABLE PART ONLY. GET YOUR
MODEL # AND PURCHASE A SET OF SOLENOIDS IF YOU ARE SURE THAT IS THE PROBLEM. THE INSTALLATIONS INSTRUCTIONS SHOULD BE IN THE PACKAGE.
BE SURE YOU CHECK FOR A BAD THERMAL FUSE, CYCLING THERMOSTAT, HIGH LIMIT THERMOSTAT, BAD
TEMPERATURE SWITCH, MOTOR CENTRIFUGAL SWITCH, TIMER, AND RADIANT SENSOR. THEY ALSO WILL CAUSE A NO HEAT CONDITION.
Jun 24, 2008 • Dryers
4helpful
2answers
Kenmore Dryer - Ignitor will not fire
thanks for the question The problem is with a thermal fuse located at the back remove back panel the thermal fuse is located on the air vent 2 small wires go to it replace it . And check the venting make sure the vent is clean because this termal fuse will break down because of poor venting Thanks for the question The appliance doc
4helpful
Kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Apr 10, 2008 • Dryers
 Grubhead
Grubhead
SmartAviator
SmartAviator
