I am attempting to repair the 240V to 12V section of an Engel portable fridge freezer power supply, but a resistor and a diode are so burnt I cant read any markings. Where can I get a Schematic diagram and a supply of spare electronic components for an Engel?
I need a schematic diagram of a fridge
I do a lot of various fridge repairs. Power supplies in these small units are not well proteced from the elements and not easy to repair.(space wise). Simply if you are in a jamb, buy a 220/12 volt battery charger and do the small alteration/conversion.look for a 1.5 to 2amp charger. only downside is both items need to be used together.
I have the same problem ( 220 not working ) with my Engel and replace the following parts on the 220v pc board:
1.Cap 82 uf 400v snp - part nr 400usp82
2.Fuse ft3.15 AH 250 v
3.Coil 05 463 replace with similar coil - part nr 14c0484
All parts can be purchase from MANTECH Electronics
Jan, my Engel does the same. After you replaced the 3 components is it working again on 220V? Is your power supply also the SP-200C ? You can mail me [email protected] Thanks for your post. Almero
Personaly I have never seen a manufacturer realease that sort of infomation.
Would suggest you contact engel direct. www.engelaustralia.com.au
Hope this is of some help
I'm sorry, but I don't have access to specific schematic diagrams or spare parts information for the Engel Portable Fridge/Freezer. My training data includes a wide range of information up until January 2022, but it doesn't include specific technical details for individual products, especially proprietary or specialized equipment.
For the information you're looking for, I recommend reaching out to Engel or an authorized Engel dealer directly. They should be able to provide you with the specific technical documentation and spare parts information for your Portable Fridge/Freezer model.
If you have the user manual that came with your Engel Portable Fridge/Freezer, it may contain some technical information, including a basic schematic diagram. If you don't have the manual, you might be able to find it on the manufacturer's website or by contacting their customer support.
Additionally, if you're experiencing a specific issue with your Engel Portable Fridge/Freezer, you may want to describe the problem in more detail. I can try to provide general troubleshooting advice based on the information you provide
My 4 year old Engel started smoking recently when the compressor runs. I have inspected the power supply board (same as ''anda2's'' comment) but can't see the faulty component. The fridge runs for a few seconds, then cuts out and starts smoking. Any help dearly appreciated.
Are all engel fridges/freezers 12/24 volt?
Hi
I bought a fridge from someone who told me it keeps drinks ideally cold at 2 degrees. At Christmas I tried it and it started freezing the drinks, I turned it down a bit and it worked fine, I then turned it off for a month, now it takes a day to drop 4 degrees with nothing in it. I suspect the switch. Where can I get a switch and how much in south Africa, Port Shepstone
